Got this older Cobra 29 for free. It had a broken leg on the audio chip so I replaced the chip and now it works. So not much into this one. Someone had molested this radio in my terms. Put a T.B., Echo board and noise toy. I've managed to get most of it back the way it should be except for the switch for the NB/ANL. Looking at schematics is not helping me at all. I'm a bit new to reading all the squiggly lines. ha.
What I could use for help is to know how to rewire the switch. I can tell from what point on the board the wires come from (schematics) but...
the switch has 8 spots to solder too. I understand that one side of 4 spots are separate from the other 4. Also that in the lower position, the two lowest spots are closed, in middle position the two middle spots are closed and the same for when in the upper position.
Can someone tell me if a jumper needs to be put across any of these and what wire goes where? No wires going to the switch now because they were used for the noise toy. Can you help this truck driver/sort-of radio repairing guy to figure this out?
Thanks.
Thanks.
