Hello everyone. I just got some new SD1446 transistors for my KL500, since the
last ones burned out. I replaced them, and all was ok, I tx'ed with 1W carrier on AM,
around 27megs and was getting some amplification. But I had an issue, the power
selector that goes from 1 to 6, had some small pieces ( that werent in place at the time )
that kept it from rotating for the other positions ( the switch has 12 positions ), and by
mistake I rotated one or two below the place where I think the '1' position is. And the
output power went down. But I was looking at the amp schematics ( rev 4.0 ) and it looks
like the switch is only a resistor selector, and position '6' should be 0 ohms, straight through
connection, so is it possible that I burned or shorted out these new transistors by rotating
the switch to some other position? Or maybe some other component maybe attenuating
output power? I tested one of the transistors ( I took it out of the amp ) and it still has an Hfe
of 130, but using the diode tester mode it showed that the collector / emitter connection
had a value of 0.520 or so ( and I think it should read O.L. ). Any help is appreciated.
Thanks in advance,
Joao G.
Thanks in advance,
Joao G.
