Had one of these come in. No TX. Found final bad. No big deal. Repalced and all was fine.
Put it back on the bench one more time before calling the guy. Noticed that the low channels was dropping off about 8 channels down below 1. Checked high and no out put at all.
On channel 20 radio dead key is 2 watts. As you go hiher in frequency (channel 35) over half the power is gone. Same below channel 20.
Radio is no longer broadbanded enough for the normal 40. I have seen this problem years ago. But can not remember what it was. I tuned the VCO and made no difference. I ws thinking there was a zener diode that supplied voltage to the coil. Can not find it on the schematic. Checked for cold joints also.
Any ideas to jarr my memory?
Thanks.
Thanks.
