Sure do love these little testers!
Discussion in 'CB and Export Equipment and Accessories' started by Chevboy0167, Aug 12, 2017.
  1. Chevboy0167
    Chevboy0167
    Expand Collapse
    New Member
    Apr 5, 2017
    21
    3
    http://www.ebay.com/itm/12864-Mega3...803031&hash=item2cc4622763:g:~-IAAOSwcNxZjLYA
    Have a Connex 3400HP here that had a direct short to pc ground. Blew fuses in both sides of my power cord or trip the power supply the first 2 times tried to power up. Take covers off to see someone soldered a small trans former on top of the stock transformer already soldered to pc board, with an axial electrolytic to neg power jack terminal. Other lead of added xformer was to pos side of power jack. Hot lead from main PC board was removed from power jack and soldered to added xformer where the extra cap was added. Now looking at all this, the added xformer looked funny... as in it has gotten hot and melted/deformed. Only thing that comes to mind is this was added for an extra filter circuit maybe? Didn't care, removed it all. Found 2SB827 shorted, 2SA1869 open and traced it all back to driver and 1 final bad. This rig uses IRF520 for driver and both finals. Point here is this little tester showed me the difference in the failures compared to the good final. Time to order parts. I will try to add some pics here.....
  2. Chevboy0167
    Chevboy0167
    Expand Collapse
    New Member
    Apr 5, 2017
    21
    3
  3. Chevboy0167
    Chevboy0167
    Expand Collapse
    New Member
    Apr 5, 2017
    21
    3
  4. Chevboy0167
    Chevboy0167
    Expand Collapse
    New Member
    Apr 5, 2017
    21
    3
  5. melaza
    melaza
    Expand Collapse
    Aug 19, 2012
    54
    8
    Autozone has the right tool!!
    tecnicoloco likes this.
  6. Robb
    Robb
    Expand Collapse
    Yup
    Dec 18, 2008
    10,167
    2,004
    Driver is blown.
  7. Limeybastard
    Limeybastard
    Expand Collapse
    May 29, 2017
    606
    I also like that those "pill" testers that show what wattage they are capable of.
  8. Tallman
    Tallman
    Expand Collapse
    W9WDX Amateur Radio Member, KW4YJ EXTRA class
    May 1, 2013
    1,549
    712
    I have one of those and it is a good quick way to verify a bad part. I have a component tester built in to my oscilloscope and it shows a bad transistor very clearly.
    This trace below is made from the ms1051 from RMI Italy.
    Check out the other wave forms in my album, all of those transistors were never installed or soldered on. I learned to test those before installing in the amps.
    [​IMG]
    LeapFrog likes this.
Share This Page
