Swr questions
Your radio gets "hot" ??????
What kind of SWR reading do you get when it's cold?
If the SWR only rises above the danger level * ONLY * when the radio overheats, this suggests a radio problem.
And if the SWR is high when the radio is cold, you really need to fix the cause of that before you roach the radio.
Reactions: Sonar
    63Sprint has left the room.
