Hi, i am looking to get a texas star dx667v turbo mod model or one thats ay's two thirds kilowatt on it, reason being i have heard those were the best one's made, so anyone have one for me??
it doesnt matter what is written on the front of it or the makers claims . it doesnt change what the final 4 pills are capable of . toshiba designed , specs and manufacturers those 2879's and they say they are good for 100 watts pep . many folks that get a 667 wind up wishing they just got a 500 instead and sometimes you see post by folks asking how to bypass the built in driver pill .
in the CB world of amps the watt claims by most amp builders cant be trusted or relied on for clean power output . some will even clain the 2879's will do 300 to 400 watts each ......... smoke and mirrors
I'm not nearly as experienced as a lot of you guys, but pretty sure 30 or 40 watts into a 667 is WAY too much drive. The way i had it explained to me was anything more than a 148 is going to be too much for the 2290 driver in there. Just my .02
The 2SC2879 is rated at 100 watts PEP at 12.5 volts. Most run their mobile gear closer to 14 volts, so the output will increase some. I'm guessing that you can probably expect to see about 125 watts per transistor before it starts to saturate.
The Cobra 148GTL is a more appropriate radio to drive this amp then anything that produces 45 watts PEP.
