Still mostly using 400-500Mhz, non trunked. They need to upgrade to P25 Phase II Encrypted.
Yeah I think it's a budget issue. Neighboring Nassau County, LINY just dropped thier analog simulcast. Running full P25 PhaseII encryption(Talk Group Key Needed). They received DHS cash to purchase. The Motorola Service techs are afraid to power up thier test radios just to listen, it's got GPS/ID. Scanners are worthless, no RX.NYPD? REALLY?? Even up here our RCMP province wide including the little rural backwater detachments are on 800 MHz TMR with encryption.
It doesn't take much to outfit a little backwater detachment, upgrading a system on the scale of what the NYPD needs is a significantly larger undertaking.
It takes time. You have to run both systems in parallel to work ou the bugs. NYC Probably waiting for a DHS grant.
