I WAS LOOKING AT THE AN-762
KIT FOR A CB AMP WHAT IS THE
BEST ONE ALREADY ASSEMBLED.
THAT WILL MEET THE FCC IMD
HARMONIC SPECS. OR IS THERE ONE???
THANKS TONY
I guess I'm the only one that doesn't splatter with an Xforce??? Hmmm
Then mine are 6 years old
THANKS TONY
While illegal as numerous has already passed along, the AN762 is a AB amp kit designed by Motorola years ago. Its a good kit but you will need to add some filtering to cut down on splatter. If you get it from CCI you should get the 10 metre filtering kit as well and do slight mod for 11 metres.
