TX five hundred
Zasha83
New Member
Aug 14, 2017
And old trucker friend of mine gave me this amp, said it doesn't work anymore due to keying up once with a high powered radio. Oops!
So I took the cover off and I did find some crispy resistors.
Trying to replace them but having some trouble identifying and finding the parts.
Circuitry novice but I'm good with a soldering iron, and I could use a little help...
Looks like someone has been in here before, some resistors have different color codes than I've found in other photos.
Am I going about this the right way?
Can anybody tell me what parts I need?
Yes, It's dead, Jim.
The only sensible repair is to replace all four of the 2SC2290 transistors and all the smoked resistors.
Excessive drive power is a one-chance only kind of mistake. The transistors that have failed are what toasted the resistors. The visible damage is a side effect of the breakdown inside those white ceramic-topped RF power transistors.
There may be other damage outside the area shown on the pic, but four 2SC2290 transistors and all the smoked resistors will be the starting point.
    Tucker442 has left the room.
    LIVE 10:00 AM EST :cool:
  • @ Charles Edwards:
