TYT TH-UV3R Dual Band Micro HT Review
So, mine didn't come with the lapel mic/earphone. It's not listed in the manual as an accy, so Moleculo must have gotten a freebee thrown in his box by the vendor he used to sweeten the deal.
The belt clip is neigh unusable. It's not a spring loaded clip, and it's so stiff that I can't get it over my belt and it's really hard to even clip it to my jeans pocket. I suppose I could thread my belt through it. On the plus side I don't think you would have to worry about it coming off accidentally.
I don't like the volume control scheme.
Functionally, yeah, I like it. The case and buttons feel as nice as my FT-60. I'ma put a bnc adaptor on it so I can easily hook it up to a mag mount antenna on the wife's car.
I programmed mine with a usb cable. You've got to have the good 'ole serial adaptor usb cable.
When I first got mine, it didn't work. I'm wondering which version of the software you have and also if there is any way to tell what firmware is on your radio?
I used the software bundled with the radio - I'll have to check to see if it lists what version it is. I'm not sure if it will say what firmware I am using.
My software is Ver 9.01, dated 18/02/2009.
Haven't figured out how to check the version of the firmware yet.
tyt
HI GUYS
My friend has a number of these tyt radios and needs to find where you get a programming cable, also the software...any suggestions
THANKS
DOCTOR
Here is what he has
TYT TH-9000 and the HT's are TYT TH-UVF9 Dual band two different versions, and one TYT TH-UV3R.
Thanks Moleculo for the excellent review and tips. Finally I now know what menu #1 TX_SEL does! (unrelated) I couldn't get mine to scan in CH mode until I realized you must add scan to each channel using menu #6.
There is however one thing in error - the Sanyo DB-L20 will NOT fit the TYT TH-UV3R.
I ordered 2 on spec and they are much different. (anyone need them?) Best price I have seen is real TYT batteries for ~$9.
This TYT is a very nice little radio - bought my 2 from a west coast Canadian dealer (Fleetwood), very good service. Unlike my Wouxun KG-UV6D V2, the TYT allows some control of the backlight and it doesn't have to remain on while scanning. These radios will be super for kayaking.
use .dat file for TH UV-3r
Hi,
I have the UV-5R and i made a file that and with .dat. I cant use the Boffeng file for this radio. Can you tald me what to do? I have the softwer from TYT.
Thanks,
Oren
Hi Mole:
Was wondering if the RX on the TYT has the same 'barn door wide open' problem as the Baofeng - when using simplex.
The Baofeng will hear NWS freq on 146.520 - which as you know is almost 10mhz away - lol.
Just wondering if it has the same problem in simplex.
Do we know which aftermarket battery works ?
DB-L80 ?
DB-L40 ?
What are the physical dimensions of the TYT battery ?
Is the + terminal on the outer edge as with the Sanyo camcorder batteries ?
VK3FORK
    63Sprint has left the room.
