WDX CB 48 hour Contest Jan 17, 18 2015
binrat
WDX Club Coordinator
Staff member
Nov 5, 2008
2,615
1,527
173
The Great White north
OK,
January's contest, here is the details.
  • Only contacts with other WDX members count in the contest. The roster may be found as a sticky thread located http://www.worldwidedx.com/threads/wdx-roster-11-30-2014.28909/
  • Channels: 20-29 AM, 30-39 LSB
  • Date/Time: 01/17/15, 0000 Zulu through 01/19/15 0000 Zulu. If you're not sure how UTC time works, check here http://www.timeanddate.com/worldclock/converter.html?p1=3875
  • Logs must be posted in the WDX Club Contest Contacts forum by the end of contest. Create only one thread for your contacts. You can edit or reply to your own thread, using it as your log throughout the contest. The format is attached as an Excel file. It may be an excel attachment OR pasted into your thread. At the end of the contest, the contacts forum will be locked, so make sure you upload all of your contacts before the end date/time.
  • There is a 2x multiplier for mobile, portable, or maritime contacts. If you operate as mobile, maritime, or portable during the contest, you are credited with the multiplier for any contacts you make. If you operate as a base, you receive a multiplier for any contact you make with a mobile, portable, or maritime contact. 3x multiplier for any contacts outside of CONUS and Canada. Make sure you clearly designate these in your log
  • No amplifiers allowed, CB legal limit.
  • Contacts will be verified against each others' logs
  • This is an "on your honor" contest and intended to be fun. Please play by the rules
  • BE A COURTEOUS OPERATOR, PROMOTE THE SITE, AND MOST IMPORTANTLY HAVE FUN!
If I have missed anything or something is not clear, please post up for clarification.
  • contest log..xlsx
Reactions: wavrider
Well done binrat! Can't wait for this one. There maybe a misprint for the AM channels though as you have them listed as 29-29, maybe it's supposed to be 20-29? Just a heads up. But the rule changes are perfect, you took everyone's ideas and did a great job. Thanks for spending your time to put this together!
hahaha, fat fingers, little keyboard. You are correct.
sounds like fun yet again, thanks Binrat for your time and effort
Binrat, in the past (long ago past) if we won...we had to stand down for the next contest. Is it still the same?
:p:p:DNo way Marconi, you have to keep your title man, propagation wasnt the best last one and I don't think it would be fair if you had to sit out. Defend the title at least for this one more, tnen if you kick out butts again you can sit down LOL!!!
Reactions: binrat
I will be there with you guys, good Lord willing. I will be using my Gain Master this time.
    63Sprint has left the room.
