Wouxun KG-UVD1P HT Programming Tutorial by KJ6HYC
KJ6HYC
Sep 27, 2010
31
3
18
Manual programming of the Wouxun Handy Talkies (HT's) can be confusing. This is a simplified procedure to manually program the HT.
Overview;
To program the Wouxun HT you must understand that you must program the numerical information (the Channel - Frequency - Freq. Offset & direction - tones) in the Menu 21 "Frequency" mode and then save it, you then change the mode of menu 21 to "name" mode and then enter the (Repeater's Name) and save it.
Notes: when you are programming the HT in menu modes you have approximately a 4 second time window to make a change, if change is not made in that time window, the HT times out and you will have to re-do the entry, usually by pushing the red "menu" button twice takes you back to where you timed out. You may also use the Frequency knob nearest to the antenna, in place of the arrow up/down to change the parameters once in the programming mode.
Procedure;
First thing is to have the programming data avaiable. I would suggest make a programming sheet that has the following programming data.
1. Frequency in 6 digits (XXX.XXX)
2. PL / CTCSS Tone frequencies (if used)
3. Repeater frequency offset and direction (if used).
4. Name of the programmed frequency in 6 characters or less (repeater name etc.)
5. Assignment of the the Wouxun memory position number for the display.
Power on the HT and press the green "TDR" button. Press the red "Menu" button and then the 1 (menu 1), then the red "Menu" button again, using the arrow up/down until “STEP" "5.00" is indicated on display, then press red "menu" button to save it.
Menu 21 (frequency mode) Press the red "Menu" button and then the 2 and 1 (menu 21), then the red "Menu" button, press the arrow up/down until "FREQ" is indicated on display, then press red "menu" button to save it and then the "Exit" button (you should have a upper display with a frequency number on it (XXX.XXX). Using the HT's key pad input the desired "repeaters" frequency using all six digits (XXX.XXX) and verify on the display.
Menu 16 (PL Tone mode) Press the red "Menu" button and then the 1 and 6 (menu 16), then the red "Menu" button, using the arrow up or down buttons until "the desired tone freq" is indicated on display, then press red "menu" button to save it.
If you are using CTSS, tone encoded squelch, repeat the tone mode above, using menu 15 in place of menu 16.
Menu 24 (Frequency offset DIRECTION) Press the red "Menu" button and then the 2 and 4 (menu 24), then the red "Menu" button, using the HTs key pad to enter the repeaters frequency offset direction "SHF-D"(+ / - / off), then press red "menu" button to save. The display should now display the offset direction.
Menu 23 (Frequency offset) Press the red "Menu" button and then the 2 and 3 (menu 23), then the red "Menu" button, using the key pad enter the repeaters frequency offset, then press red "menu" button. The display should now display the offset frequency (XX.XXX).
Menu 27 (Saving (MEM-CH)) This saves your entered data, Press the red "Menu" button and then the 2 and 7 (menu 27), press the red "menu" button, then using the UP/Down arrow buttons select the memory number you would like to save the data in, and once selected push the red "menu" button to save. NOTE: If the numbered memory location is used the "CH-"XX is displayed and if you push the red "menu" button you will over write that channel. If there is only the memory number displayed (NOT the "CH-"), that memory location is unused and available for storage.
Menu 21 (NAME mode) Press the red "Menu" button and then the 2 and 1 (menu 21), then the red "Menu" button, press the arrow up or down until "NAME" is indicated on display, then press red "menu" button. After 5 seconds, the display should now display a six digit name (CH-XXX).
Menu 26 (Channel Name) Press the red "Menu" button and then the 2 and 6 (menu 26), then the red "Menu" button, for this function you use the channel/frequency KNOB, nearest the HTs antenna. When the knob is rotated clockwise (CW) the digits advance (A-Z and 0-9) and then repeat, then you rotate the knob counter clockwise (CCW) the "space" advances. If you over advance, it will wrap around. Once you have the name spelled out, you must quickly save it (4 second time out) or you will loose it.
The above is for repeater setup, for simplex operation the menu 24, 16 & 15 ="OFF", Menu 23 = "00.000".
73's
Wayne - KJ6HYC
FWIW
In case it isn't clear, this will work on the 'KG-UV2D' series of hand-helds.
From what I've been able to find out, the only difference between the 'UV1' and 'UV2' series and the 'KG-UV4', is that the 'UV4' has an intermediate power setting rather than just 'High' and 'Low' power setting. (I ca certainly be corrected about that!)
Also noticed that the new 'mobile' radio Wuoxun advertises can display '7' digits instead of the typical '6' when in the '12.5' "step". Displays them all the time?
The other difference is that they changed the channel name/number/frequency display to make it stick to what you set it at. Right now, it defaults back to the factory default every time you turn it off, which is real annoying.
I have the KG-UVD-1P (144/440), and the KG-UV3D (144/220). I haven't had the channel name/number/freq. defaulting to factory problem with either. Perhaps a software update may cure?
73's
KJ6HYC
My UVD1P only does the crazy name/number/freq change after switching from memory mode to VFO mode(I don't remember what the manual calls it? work mode?). I jjust checked it tonight and I can turn it off all I want after having the memory set to channel name but after switching to VFO by pushing MENU then TDR and going back to memory by pressing MENU then TDR I get stuck with channel number instead of name. Its still a very good HT for the money
Thank you!
Manual programming of the Wouxun Handy Talkies (HT's) can be confusing...
73's
Wayne - KJ6HYC
Great post! Thank you!
We have severe icing going on in central Alabama today and an operator needed to set up his HT while on the road.
I was able to find and use this clear helpful guide to get him up and running.
Fine Business!
Ed
73 de W4AGA
I just got mine today from cheapham.com. for $109.90 shipped. It came with the 1700ma battery . Ordered it Wed. evening and got it this morning ! The audio sounds great ! Seems like a very nice HT . Can't wait to mess with it some more. Just ordered th programming cable that comes with the CD .
Overview;
Procedure;
73's
Wayne - KJ6HYC
    63Sprint has left the room.
