Wow!!! Galaxy LC 998v most expensive export?
Discussion in 'CB and Export Equipment and Accessories' started by undertaker, Jul 12, 2017.
  1. Limeybastard
    Limeybastard
    Expand Collapse
    May 29, 2017
    725
    107
    I learned in the small time that I've spent on here and experimenting that watts means nothing without at min a half decent antenna setup. Throw all the watts you want , just wasted energy. ( Talking out aloud to myself )
    kc0lrp and rabbiporkchop like this.
  2. Limeybastard
    Limeybastard
    Expand Collapse
    May 29, 2017
    725
    107
    Im not sure about the heat on the FFB4, but on the N4 the heat aint so much the amp unit but the mosfet or whatever they are called that are mounted on the side of the chasis frame.
  3. Troubleshooter
    Troubleshooter
    Expand Collapse
    Supporting Member
    Jun 13, 2016
    195
    47
    Like I said, if they are tuned correctly heat will usually not be a problem, but most try to get the most watts out of them , heat then becomes an issue. I have heard a number of people were blowing mosfets in the N4 because of an improper tune... I could be wrong though...
    #18 Troubleshooter, Jul 16, 2017
    rabbiporkchop likes this.
  4. Limeybastard
    Limeybastard
    Expand Collapse
    May 29, 2017
    725
    107
    Even low power it gets hot, fb754 region , noticable when amp cover removed. IMG_20170620_005523.jpg
  5. Troubleshooter
    Troubleshooter
    Expand Collapse
    Supporting Member
    Jun 13, 2016
    195
    47
    Gotcha, they do run hot, I said that.. :) But if tuned correctly and not over driven with a very aggressive tune to squeeze every watt you can get, then heat usually will not cause an issue with blown mosfets or pills in the amplifier section..
  6. rabbiporkchop
    rabbiporkchop
    Expand Collapse
    Jan 18, 2007
    1,319
    349
    Without a very aggressive tune to remove all the IMD it will get hot.
    It's a shame they couldn't spend a few extra bucks per unit and use beta matched transistors to eliminate some of that IMD.
  7. undertaker
    undertaker
    Expand Collapse
    Undertaker
    Apr 5, 2006
    1,543
    380
    That is why you get the radio from a reputable shop....
  8. rabbiporkchop
    rabbiporkchop
    Expand Collapse
    Jan 18, 2007
    1,319
    349
    There's varying degrees of reputable also.
    The ones that think the laws of physics don't matter when it comes to taking precise measurements are the ones that slightly misalign every radio that crosses their bench even though they have good intentions.
    It stands to reason that if someone's bench isn't configured to take precise measurements then any adjustment they make will be slightly wrong.
    #23 rabbiporkchop, Jul 16, 2017
  9. loosecannon
    loosecannon
    Expand Collapse
    Mar 9, 2006
    2,693
    922
    you guys just don't get the finer points of Galaxy radio design.
    They design them to run hot on purpose. It serves to heat up the oscillator crystals faster in order to minimize drift. :whistle::whistle::whistle:
  10. rabbiporkchop
    rabbiporkchop
    Expand Collapse
    Jan 18, 2007
    1,319
    349
    If he's only charging $100 for $279 worth of parts, that's a big red flag.
  11. rabbiporkchop
    rabbiporkchop
    Expand Collapse
    Jan 18, 2007
    1,319
    349
    A matched set of four red dots only saves you $7 so that's still $171 more than he's charging you. Something sounds fishy.
  12. Limeybastard
    Limeybastard
    Expand Collapse
    May 29, 2017
    725
    107
    I saw a video where Jokerman, retested these transistors and found they were not always truly marched. It pissed him off it would appear in the video.
  13. Yeti Communications Ltd
    Expand Collapse
    Sep 15, 2015
    264
    320
    jason..(jokerman) the beta test he was doing is not the same gear the manufacturers use so therefore the current applied is different so therefore the reading is different ..most beta testers for transistors are for small signal transistors not rf finals which require more current to switch on ..the results will be different.
    if the test unit can not supply the necessary needed parameters to even switch the transistor on correctly how is one to expect a consistent resultant reading? ..many have posted videos on youtube of this fact (so called amp "builders" etc) ..it was actually me that pointed this out to jason some months ago ..now hes changed his "tune '
  14. rabbiporkchop
    rabbiporkchop
    Expand Collapse
    Jan 18, 2007
    1,319
    349
    If you pay RF Parts the extra fee, they will beta match them for you.
    I Don't think any amplifier builders go the extra mile to provide that extra value to their customers.
  15. Limeybastard
    Limeybastard
    Expand Collapse
    May 29, 2017
    725
    107
    Yeah, he was basically using a meter called a cricket? Alot of the figures matched on what was supplied to him but some didn't. If that makes any sense. I think RF parts was written on the packaging.
Share This Page
