Yaesu FT-920 MARS
Tom G
New Member
May 3, 2015
3
Savannah, Ga (EM92)
qrz.com
Hi All,
I know this is going back some, but does anyone have complete instructions for opening the 920 for MARS?
My serial number is 7F030408, and I've done the following vis a post here, but without positive results (and thankfully no negative ones either-that I know of):
1. clipped the green wire under the DSP unit
2. pressed and held STEP and LOCK while powering on
3. Entered " 1 9 8 4 1 2 9" and pressed enter.
Still unbale to xmit outside the band, and seem to think I need to tell the rig it can xmit. Similar to the 5Mhz mod where the F-menu is accessed.
Can anyone out there help in this area?
Thanks,
TomG-KG3Z
When I bought my FT-920 in the 90's there was software available to change the transmit range from one continuous block or small blocks just outside bands. I even think that Yaesu offered the software. Its lost to me on a dead computer.
I just bought a 920 and its problem is that the screen is empty (only dark orange back light). There is no short (draws only a little over 1amp) and the relay clicks when turned on as usual but no audio in speaker or led's in front. Is it worth repairing?
    63Sprint has left the room.
