Cherokee
CBS1000
Parts List
Receiver Section
ID |
Function |
Mfg. |
Part # |
Q1 |
NB |
KEC |
KTC3193 |
Q2 |
NB |
KEC |
KTC3193 |
Q4 |
NB |
KEC |
KTC3193 |
Q3 |
NB S/W |
KEC |
KTA1267 |
Q5 |
NB S/W |
KEC |
KTA1267 |
Q16 |
NB S/W |
KEC |
KRC111 |
Q9 |
RF AMP |
KEC |
KTC3195 |
Q10 |
1st MIXER |
2SK163 |
Q12 |
IF AMP |
KEC |
KTC3195 |
Q13 |
IF AMP |
KEC |
KTC3195 |
Q14 |
IF AMP |
KEC |
KTC3195 |
Q15 |
IF AMP |
KEC |
KTC3195 |
Q25 |
AM S/W |
KEC |
KRC111 |
Q7 |
2nd SSB MIXER |
KEC |
KTC3199 |
Q24 |
AM S/W |
KEC |
KRC111 |
Q23 |
SSB S/W |
KEC |
KRC111 |
Q43* |
RF Gain Control |
KEC |
KTC3195 |
Q57 |
WX S/W |
KEC |
KRA101 |
Q59 |
WX SW |
KEC |
KRC111 |
Q44 |
WX VCO |
KEC |
2SK192A |
Q46 |
WX VCO BUFFER |
KEC |
KTC3880 |
Q47 |
WX RF AMP |
KEC |
KTC3880 |
Q54 |
WX MIX |
KEC |
KTC3880 |
Q65 |
WX IF AMP |
KEC |
KTC3880 |
IC1 |
SQ, METER, AGC CONTROL |
ROHM |
BA728 |
IC9 |
WX DETECTOR |
ROHM |
BA403 |
*NOTE:
Q43 Is a misprint...� This is most likely Q12, as it is in the feedback loop
for RF Gain
Audio Section
ID |
Function |
Mfg. |
Part # |
IC8 |
MIC AMP |
KEC |
KIA4558 |
Q26 |
AM S/W |
KEC |
KRC111 |
Q29 |
ALC CONTROL |
KEC |
KTC3199 |
Q31 |
ALC CONTROL |
KEC |
KTC3199 |
Q30 |
ALC CONTROL |
KEC |
KTA1267 |
Q37 |
SSB ALC CONTROL |
KEC |
KTC3195 |
Q71 |
AM MODULATION AMP |
SANYO |
2SB824 |
Q50 |
SSB S/W |
KEC |
KTC3199 |
Q72 |
AM MODULATION AMP |
KEC |
KTC3199 |
Q67 |
MODULATION METER AMP |
KEC |
KTC3195 |
IC3 |
BALANCE MIXER |
NEC |
UPC1307 |
IC5 |
AUDIO POWER AMP |
KEC |
KIA7217 |
TX Section
ID |
Function |
Mfg. |
Part # |
Q38 |
POWER |
MITSUBISHI |
2SC1969 |
Q40 |
DRIVER |
MITSUBISHI |
2SC2166 |
Q41 |
PRE DRIVER |
SANYO |
2SC2314 |
Q42 |
PRE DRIVER |
KEC |
KTC3192 |
IC6 |
MIXER |
KEC |
KIA6058 |
PLL Section
ID |
Function |
Mfg. |
Part # |
Q17 |
CHARGE PUMP |
KEC |
KTC3199 |
Q18 |
CHARGE PUMP |
KEC |
KTC3199 |
Q19 |
VCO AMP |
KEC |
KTC3195 |
Q20 |
4.5 MHz OSC |
KEC |
KTC3880 |
Q21 |
VCO OSC |
KEC |
KTC3195 |
Q22 |
VCO AMP |
KEC |
KTC3195 |
Q33 |
10.695 MHz OSC |
KEC |
KTC3195 |
IC201 |
CONTROL & PLL |
HYUNDAI |
LC7232 |
IC202 |
AM� SSB S/W |
MOTOROLA |
MC14066 |
POWER SUPPLY SECTION
ID |
Function |
Mfg. |
Part # |
Q35 |
TX S/W |
KEC |
KRC110 |
Q36 |
TX S/W |
KEC |
KTA200 |
Q68 |
CLARIFIER S/W |
KEC |
KTC3875 |
Q69 |
CLARIFIER S/W |
KEC |
KTC3875 |
Q74 |
AC/DC CONVERTER |
KEC |
KTB778 |
Q76 |
AC/DC CONVERTER |
KEC |
KTC1027 |
Q73 |
AC/DC CONVERTER |
KEC |
KTC200 |
Q74 |
AC/DC CONVERTER |
KEC |
KRC111 |
Q203 |
TX S/W |
KEC |
KRA101S |
Q204 |
HOLD S/W |
KEC |
KTA1504 |
IC4 |
8 VOLT REGULATOR |
DAEWOO |
78L08 |
IC5 |
5 VOLT REGULATOR |
KEC |
78S05 |
