Cherokee
CBS1000
RX ALIGNMENT
RX - CB Band
Step |
Control/Function |
Connection / Set Up |
Adjust |
Observe / Result |
R-1 |
RF
Gain Max |
�A.� RF Signal Generator to ANT B.� Frequency to 27.215, 30% AM Modulation C.� Generator Level 3.0 uV D.�� Scope / Audio Meter to External Speaker Jack |
SSG Level |
Signal
With Noise |
R-2 |
Same |
Same |
Volume |
Set
to 0.8V Across |
R-3 |
Same |
Same |
L30,
L31 |
Maximum
Output |
R-4 |
Same |
Same - Reduce SSG To 1.0 uV |
Same |
Maximum Output Volts |
Weather Band
Step |
Control/Function |
Adjust |
Observe / Result |
W-1 |
Channel
Selector |
RF Signal Generator to ANT Frequency to 162.550 MHz 4 KHz FM Deviation Level to 1 uV |
L22 L23 |
W-2 |
Same |
SSG Level to 30 uV |
L24 |
Minimum
Distortion |
