Cherokee
CBS1000
SPECIFICATIONS
Channels: |
AM4OCH. USB 40CH. LSB 40CH. WX (Receiver) 10CH. |
Emission Type: |
USB. LSB (A3J). AM(A3) |
Controls: |
CHANNEL SELECTOR, VOLUME, SQUELCH, REGAiN, MIC-GAIN, CLARIFIER, SWR/CAL, CAL/SWRIMOD, MODE, LCR, SCAN, DW, NB, ANL, CH9, CH19 |
Jacks: |
Antenna, Mike, External Speaker, Head Phone |
Display: |
L.C.D. Panel, SRF/Analog Meter, MOD/SWR Analog Meter. |
Frequency Range: |
26.965MHz to 27.405MHz |
Supply Voltage: |
13.8V DC/120V AC Negative Ground |
Accessories: |
Plug-in Mike, DC Power Cord, Mike Hanger & Screw, Manual. |
Antenna Impedance: |
50 ohm |
Speaker Impedance: |
4-8 ohm |
Operating Temp. Range: |
-20 degrees C to 50 degrees C |
AM TRANSMITTER
RE Power Output: |
AM 4 Watts |
Modulation: |
High and Low level, Class B |
Spurious & Harmonic Suppression: |
More than 60 dB |
Microphone Sensitivity 50% Modulation: |
2mV |
A.M.C. Dynamic Range: |
More than 40 dB |
Power Drain: |
13.7 VDC, l.5A |
SSB TRANSMITTER
RF Power Output: |
12 Watts PEP |
Carrier Suppression: |
More than 50dB |
Unwanted Side Band Suppression: |
More than 50dB |
More than 60dB |
Power Drain: |
13.7VDC, 2.5A |
RECEIVER
Sensitivity: |
AM:
0.5uV for 10dB (S+N)/N |
Image Rejection: |
More than 40dB |
IF Rejection: |
60dB |
Adjacent Channel Rejection: |
60dB |
Cross Modulation: |
50dB |
Squelch Range: |
Adjustable. Threshold Less than: luV |
RE Gain Control |
30dB |
Clarifier Range: |
Coarse + 5KHz; Clarifier, � 2.5 K.Hz |
Audio Output Power: |
3 Watts @ 10% THD; 8 ohms |
Current Drain: |
Maximum: 1.0 AMP No Signal: 0.5 AMP |
