Cherokee Radios CBS2100
SUMMARY OF ALIGNMENT POINTS FOR CBS-2100 RADIO
(Refer to Alignment Procedure Section for Details) ����� ���� �����
Item
Description (Test on Ch20 - Center Freq)
Test Point
Adj. Point
AM Rx Signal Level Meter
Signal Meter on Front Panel
VR01
2
SSB Rx Signal Level Meter
VR02
3
SSB Squelch Level - Preset Level
Ext Speaker Output
VR03
4
AM Squelch Level - Preset Level
Ext Speaker Output
VR04
5
SSB Balance Modulator Output � Null
Ant RF Output - Power Meter
VR07
Tx Power Level Meter
VR08
2
SSB RF Power Output TR43 Quiescent Current - 100mA
TP7/TP9
VR10
3
SSB RF Power Driver TR44 Quiescent Current - 50mA
TP8/TP9
VR11
4
SSB TX Power Limiting
VR12
5
AM Power Output - Full Power
VRI3
6
Modulation Level Limiter -AM Full Power
Ant RF Output � Oscilloscope
VR14
7
Balance TX and RX frequency on 1st offset Freq Gen
R74 (TP3) - Clarifier at mid position
VR15
8
Noise Blanker Adjustment (With Noise Generator)
Ext Speaker Output
L01-L02
9
AM Receiver Adjustment (IF)
Ext Speaker Output
L03-04
10
AM Receiver Adjustment (Front End)
Ext Speaker Output
L06-08
11
AM Receiver Adjustment (Mixer)
Ext Speaker output
L10-12
12
SSB IF Adjustment
Ext Speaker Output
L13-14
13
PLL VCO Voltage
R116 (TP2)
L17
14
AM 1st Offset Frequency Generator
L19
15
USB 1st Offset Frequency Generator
L20
16
LSB 1st Offset Frequency Generator
L21
17
AM 2nd Offset Frequency Generator
TR46 Collector (R223)
L26
18
USB 2nd Offset Frequency Generator
L27
19
LSB 2nd Offset Frequency Generator
L28
20
RF Output at acceptable level across the band
L40/L42/L33
