Cherokee
Radios CBS2100
PLL ALIGNMENT
Connect the radio to 13.8V DC power supply, terminate the antenna terminal by a 50ohm 20W dummy load. Turn on the frequency counter, oscilloscope, digital multimeter and the radio, wait 30 minutes before adjusting any frequency determining components.
A. Reference Oscillator Frequency Check [10.2400 MHz]
1. | Connect the frequency counter to pin terminal between C-83 and C-85. |
2. | Check counter reads 10.2400 MHz. |
3. | Tolerance within � 200 Hz is acceptable. Otherwise replace the 10.24MHz crystal. (if frequency error is more than � 500 Hz, change C-81 for other values for freq. Correction) |
B. Second Offset Frequency Oscillator Check 10.695MHz [AM] 10.6925MHz [LSBI 10.6975MHz [USS].
1. | Connect frequency counter toTP-6 (C73/D27). |
2. | 10.695MHz AM operation, Set the mode selector to AM, and press PTT key switch to transmit, adjust L-26 to obtain 10.695MHz (+0, or -100HZ) on the frequency counter. |
3. | 10.6925MHz LSB operation: Reset mode selector to USB. Adjust L-27 to 10.6925MHz, +0, or -100HZ. |
4. | 10.6976MHz USB operation: Reset mode selector to LSB. Adjust L-28 to 10.6975MHz, +0, or -100HZ. |
C. PLL Mixer IC Input Level Adjustment
1. | Set the mode selector to AM, and the Clarifier Control to center position. Set channel selector to CH 20. |
2. | Connect Oscilloscope to TP4 between C-106 and L-50. |
3. | Adjust L-22 for maximum RF to the Mixer input. |
D. PLL VCO Adjustment
2. | Connect Oscilloscope to TP-3 at R74. |
3. | Adjust L-18 for maximum VCO RF output. |
4. | Connect DC voltmeter to TP-2 between R-116 and R-117. |
5. | Adjust L-17 to obtain DC 3V � 0.1V VCO Control Voftage. |
E. PLL Off-set Frequency Adjustment
1) Receiving Mode:
1. | Connect frequency counter to TP-3 at R74. |
2. | Set the mode selector to AM, and the Clarifier Control to center position. |
3. | Set channel -selector to CH. 20. |
4. | Adjust L-19 for 16.510 MHz + 50Hz. |
5. | Set the mode selector to USB. |
6. | Adjust L-20 for 16.5125 MHz � 50Hz. |
7. | Set the mode selector to LSB. |
8. | Adjust L-21 for 16.5075 MHz 50Hz. |
2) Transmiting Mode:
9. | Set the mode selector to LSB, and press PTT to transmit. |
10. | Hold-on Tx key switch [PTT] and adjust Trimmer Pot. VR-15 for frequency correction to 16.5075 MHz � 50Hz, release PTT and observe the frequency is the same for Tx and Rx. |
