Cherokee Radios CBS2100
TRANSMITTER ALIGNMENT
Note: Unless otherwise specified, adjust Mic Gain control on the front panel to fully clockwise position for all following tests.
A. Test Set-Up
Set up test equipment with the CBS-2100 radio as indicated below:
B. SSB Balanced Modulator Adjustment
1. Set the mode selector to USB, and the channel select to CH 20.
2. Adjust Mic Gain control on the front panel to minimum (fully counterclockwise).
3. Press PTT to transmit on SSB without modulation.
4. Adjust VR7 for minimum RF output.
5. Check RF output on LSB is also minimum.
6. Resume Mic Gain control to maximum setting (fully clockwise).
C. RF Power Transistor Bias Current Adjustment
2. Remove the short link PCB (installed vertically in front of the RF Power transistors).
3. Connect 100MA FS DC current meter to TP-9 [+] and TP-8 [-].
4. Adjust VR11 for 60mA � 3mA to TR44.
5. Connect 200mA FS DC current meter to TP-9 [+] and TP-7 [-].
6. Adjust VR10 to 100mA � 5mA to TR43.
7. Install the short link PCB back to the holder of TP-7, TP-8 & TP-9 upon completion of adjustment.
D. AM RF Power Output Adjustment
1. Set mode selector to AM.
2. Select the channel selector to CH-20.
3. Press PTT to transmit.
4. Adjust VR-13 for 4W RF Power output. (Without modulation)
E. RF Power Amplifier Adjustment
IMPORTANT: VR-12 Bias adjustment, should not be rotated clockwise beyond 2 o'clock position, otherwise the RF transistor may be destroyed.
1. Set the Mode Selector to USB. Compander OFF.
2. Apply 1 KHz 50mV RMS audio signal to Microphone input connector pin 2.
3. Set the Channel Selector to CH-20.
4. Press PTT to transmit.
5. Adjust VR-12 and L-42 for Maximum RF power output as read on the RF Watt Meter.
6. Adjust L-40, L-43, L-44 and L-33 for max. RF power output.
7. Repeat step 4 to 5 until no further improvement is obtained.
8. Adjust L-42 for balanced RF Power output on CH40 & CH1.
9. Switch to AM Mode, disable audio signal generator, press PTT to transmit.
10. Adjust VR-13 for 4W RF Power output on AM Mode with no modulation.
11. Switch back to USB Mode, apply 50mV 1 KHz audio, press PTT to transmit.
12. Switch VSWR meter to Peak Detection Mode.
13. Adjust VR-12 for max, 12W SSS Peak Power Output.
F. AM Modulation Adjustment
1. Apply 1 KHz 50mV rms. AF signal to Microphone input connector pin 2.
2. Activate PTT to transmit in AM Mode. Compander (CDS) OFF. Adjust VR-14 for 90% modulation.
G. Compander (CDS) Functional Test - Transmitter
1. Apply 1KHz 2mV rms. AF signal to Microphone input connector pin 2.
2. Activate PTT to transmit in AM Mode. Compander OFF.
3. Observe modulation level between 20-80%.
4. Switch Compander (CDS) to ON /Auto CDS.
5. Observe the modulation level increases to around 90%.
6. Increase signal generator level from 2mV to 100MV, Compander (CDS) ON Auto CDS.
7. Observe the modulation level remains to be less than I 00%.
8. Repeat the test with CDS ON and Super CDS set to Maximum.
H. Advanced Test Procedures for Modulation
Following advanced test procedure requires optional / advanced test equipment setup by experienced technical person, and is not normally required in a field repair environment.
Modulation Level = (a-b) X 100% ÷ (a+b)
i) AM Modulation Monitor
- Apply 1KHz 50mV rms. AF signal to Microphone input connector pin 2 of the radio, and to the Y input (Usually marked as Timebase) of the oscilloscope.
- Monitor RF output waveform with X input (usually marked as CH 1) of the oscilloscope.
- Activate PTT to transmit on AM Mode. Cornpander (CDS) OFF.
- Confirm the AM Modulation displayed in the oscilloscope is less than 100% as in Fig iA.
ii) SSB Modulation Monitor
- Use two AF signal generator connected in a star resistor network to provide a balanced 3 input/output ports with impedance of 600ohm. Compander OFF.
- Apply 500Hz and 2.4KHz 30mV audio tones signals simultaneously through the resistor network to the Microphone input connector pin 2. Activate PTT to transmit on USB Mode.
- Adjust the output level of the 500Hz AF signal generator to obtain the proper waveform on the oscilloscope as shown in figure iiA. (See Fig C to D for waveforms of improperly set up radios)
iii) FCC Emission Limitation Check
- Set up equipment as in i) AM Modulation Monitor Test, Compander OFF.
- Couple the Spectrum Analyzer input to the RF Dummy Load
- Apply 2.5KHz 50mV rms. audio tones signal to the Microphone input connector pin 2.
- Activate PTT to transmit on AM Mode, adjust AM Modulation level to 85% (see Fig iA).
- Observe on the Spectrum Analyzer that the Radio's RF output are within the FCC limits
- Repeat test with Compander (CDS) ON and Super CDS turned to Maximum.
