Cherokee
Radios CBS2100
Ref. |
Part Number |
Description of Parts |
Functional Description of Parts |
D001 |
DDE2-1K60 |
RF Diode (1N60) |
RF Detector for Noise Blanker circuit |
D002 |
DDE2-1K60 |
RF Diode (1N60) |
D003 |
DDE1N4148 |
Switch Diode (1N4148) |
Switching Diode for NB noise shunting transistor TR7 |
D004 |
DDE1N4148 |
Switching Diode - disable AM IF in SSB Mode |
D005 |
DDE1N4148 |
Switching Diode - disable 2nd Mixer in SSB Mode |
D006 |
DDE1N4148 |
Switching Diode - disable 2nd Mixer in TX mode |
D007 |
DDE1N4148 |
Switching Diode - voltage gating - Rx AGC |
D008 |
DDE1N4148 |
Switching Diode - SSB AGC attack time control |
D009 |
DDE1N4148 |
Switching Diode - AMAGC attack time control |
D010 |
DDE2-1K60 |
RF Diode (1N60) |
IF Level Detector - for Rx Signal Meter and AGC |
D011 |
DDE2-1K60 |
RF Diode (1N60) |
D012 |
DDE1N4148 |
Switching Diode - voltage gating for Signal Meter signal |
D013 |
DDE1N4148 |
Switching Diode - voltage gating |
D014 |
DDE1N4148 |
D015 |
DDEMI301 |
Pin Diode |
Protect Receiver Front end from excessive signal |
D016 |
DDEMI301 |
Pin Diode |
Protect Receiver Front end from transmitter signal |
D017 |
DDE1N4148 |
Switching Diode - Enable SSB IF path in SSB Mode |
D018 |
DDE1N4148 |
Switching Diode - Provide 10.695MHz signal to TX mixer in AM Tx Mode |
D019 |
DDE1N4148 |
Switch Diode (1N448) |
Switching Diode - Provide 10-.695MHz signal to FL3 in AM Tx Mode |
D020 |
DDE1N4148 |
Switching Diode-Disable AM receiving path in Tx Mode |
D021 |
DDE1N4148 |
Switching Diode - Disable SSB receiving path in Tx Mode |
D022 |
DDE1N4148 |
Switching Diode - Disable SSB IF amplifier in Tx Mode |
D023 |
DDE2-1K60 |
RF Diode (1N60) |
AM Demodulator |
D024 |
DDE2-1K60 |
RF Diode (1N60) |
AM Demodulator |
D025 |
DDE1N4148 |
Switching Diode-Enable SSB lFcircuitinSSB Mode |
D026 |
DDE1N4148 |
ANL circuit |
D027 |
DDE1N4148 |
Switching Diode - Mute SSB Carrier re-insertion in AM Mode |
D028 |
DDE1N4148 |
Switching Diode-Mute Rx audio in Tx Mode |
D029 |
DDE1N4007 |
Power Diode |
Voltage Clamping |
D030 |
DDESVC251 |
VC Diode |
PLL VCO |
D033 |
DDE1N4148 |
Switching Diode PLL VCO circuit |
D034 |
DDE1N4148 |
Switching Diode - LSB mode |
D035 |
DDE1N4148 |
Switching Diode - USB mode |
D036 |
DDE1N4148 |
�Switching Diode-AM mode |
D038 |
DDE1N4148 |
D039 |
DDE1N4148 |
Voltage Clamping |
D040 |
DDE1N4148 |
�Switching Diode - enable 2nd offset oscillator in SSB Mode |
D057 |
DDE1N4148 |
Switching Diode -AM mode |
D068 |
DDE1N4148 |
Switching Diode-USB mode |
D069 |
DDE1N4148 |
SSB power control TR47 in AM mode |
D060 |
DDE1N4148 |
D061 |
DDE1N4148 |
Switching Diode - Mute Squelch when PLL is out of lock |
D062 |
DDE1N4148 |
Switching Diode - Disable balanced mixer output in Rx Mode |
D063 |
DDE 1N4148 |
Switching Diode - Disable balanced mixer input in AM Mode |
D065 |
DDE1N4148 |
Voltage Clamping |
D066 |
DDE1N4148 |
Switching Diode - Disable PTT when PLL is out of lock |
D067 |
DDE1N4148 |
control |
D068 |
DDE1N4148 |
Audio Detector for automatic mic audio level control |
D069 |
DDE1N4148 |
D070 |
DDE1N4148 |
Switching Diode - ALC operation |
D071 |
DDE1N4148 |
Switching Diode - Mute Mic audio during receive mode |
D074 |
DDE1N4148 |
Switching Diode - AM mode |
D076 |
DDE-C5V1G |
Zener 5.1v ±2% On 5506 |
Voltage offset for Rx active voltage switch TR36/TR38 |
D077 |
DDEMA29A |
VR Diode (KB362) |
Switching Diode for Tx active voltage switch TR38 |
D078 |
DDE-C7V5G |
Zener 7.5V ±2% |
Reference voltage source for8V voltage regulator TR40/TR41 |
D079 |
DDEMA29A |
VR Diode (KB262) |
Bias Diode for8V voltage regulator TR40/TR41 |
D080 |
DDE1N4148 |
Switching Diode - Mute AF Power amplifier in Tx Mode |
D081 |
DOE1N4148 |
Switching Diode - PTT keying control |
D082 |
DDE1N4148 |
D083 |
DDE 2-160 |
RF Diode (1N60) |
Audio Detector for ALC operation |
D084 |
DDE1N4148 |
Switching Diode-SSB mode |
D086 |
DDE1N4148 |
Transmit level detector for TX Power meter |
D087 |
DDE1N4148 |
D088 |
DDEMA29A |
VR Diode (MV1Y) |
RF Power Transistor bias protection temperature sensor |
D089 |
DDEMA29A |
VR Diode (MV1Y) |
D060 |
DDE1N4148 |
Voltage Clamping |
D061 |
DDE1N4148 |
Voltage Clamping |
D062 |
DDE1N4148 |
Bias Control for TR53 |
D063 |
DDE1N4004 |
Power Diode |
Secondary Power Supply polarity reversal protection |
D094 |
DDE1N4148 |
Switching Diode - enable 2nd offset oscillator in TX Mode |
D094a |
DDESVC251 |
VC Diode |
PLL VCO |
D097 |
DOE1N4148 |
Switching Diode - PA Operation |
D113 |
DDE1N4148 |
Switching Diode - Disable Rx audio during PA operation |
D114 |
DDE1N4148 |
Voltage Clamping |
D116 |
DDE-C7V5G |
Zener 7.5V ±2% |
Voltage regulator for PA circuit |
D123 |
DDE1N4148 |
D124 |
DDESVC251 |
VC Diode |
PLL offset frequency oscillator - Clarifier frequency control |
D125 |
DDE 1N4148 |
Switching Diode - disable AM IF in SSB or TX Mode |
D401 |
DDE2-1K60 |
RF Diode (1N60) |
SWR signal detector |
D402 |
DDE2-1K60 |
RF Diode (1N60) |
D501 |
DDE6A05 |
Diode 6A/50V On DC Socket |
Primary Power Supply polarity reversal protection |
D601 |
DDE1N4148 |
�Switch Diode (1N4148) |
Logic Switch SSB Mode Switching |
D602 |
DDE1N4148 |
D701 |
DSG-MEL-MM4148 |
Switch Diode (1N4148) SMD |
Clock Input Switch for IC706 |
D901 |
DDE1N4148 |
Super Clear Drive Switching |
D902 |
DDE1N4148 |
D801 |
DDE1N4148 |
Logic Switch Switching |
D802 |
DDE1N4148 |
