Cherokee
Radios CBS2100
SPECIFICATIONS
GERNERAL
Frequency Range: |
26.965MHz to 27.405MHz (40 Channels) |
Frequency Control: |
Phase Locked Loop (PLL) Synthesizer |
Frequency Tolerance: |
0.005% |
Frequency Stability: |
0.001% |
Operating Temperature Range: |
-20 Degrees F to +120 Degrees F |
Microphone: |
Plug-in Dynamic; with push to talk switch & coiled cord |
Input Voltage DC or AC: |
13.8V DC nominal, 15.9V Max., 11.7V Min (DC Power Jack) AC 110-120V or 220-240V 50/60 Hz Selectable (AC Jack) |
Current Consumption (AC 115V Only): |
0.5 Amps Max Continuous, 3A surge |
Current
Consumption |
Transmit AM full modulation, 2.4 Amps Max. the DC Transmit SSB 12-Watts PEP Output, 3 Amps Max. Receive: Squelched, 0.6 Amps Max. Receive: Maximum Audio Output, 1. 0 Amps Max |
�6-3/8" (Height) x 19' (Width) x 13' (Depth) Weight-18.5 lbs |
Antenna Connector: |
UHF, S0239 |
Meters: |
Received Signal Meter, TX RF Output Power and SWR Meter |
Frequency Counter: |
5 digit 7 segment LED displays transmit receive spot frequency |
TRANSMITTER
Power Output: |
AM-. 4 Watts, SSB: 12 Watts PEP Maximum |
Modulation (AM/SSB), |
High and Low Level Class B, Amplitude Modulation |
Intermodulation Distortion: |
SSB: 3rd order, more than -25dB |
SSB: 5th order, more than -35dB |
SSB Carrier Suppression: |
55dB |
Unwanted Sideband: |
50dB |
Frequency Response: |
450-2500Hz |
Output Impedance: |
50 ohms, unbalanced. |
Output Indicators: |
Meter shows relative RF output power and SWR Transmit LED glows red when transmitter is in operation |
RECEIVER
Sensitivity: |
SSB- 0.25uV for 10dB (S+N)+N at greater than 0.5Watts audio output AM-. 1.0uV for 10dB (S+N)+N at greater than 0.5 Watts audio output. |
Selectivity |
6dB at 3KHz, 5OdB at 9KHz |
Image Rejection |
6OdB |
IF Frequency: |
AM- 10.695MHz first IF, 455KHz 2nd IF SSB- 10.695MHz |
Adjacent Channel Rejection: |
42dB at 10KHZ |
RF Gain Control: |
45dB adjustable for optimum signal reception |
Automatic Gain Control (AGC), |
Less than 10dB change in audio output for inputs from 10 to 100,000uv. |
Squelch: |
Adjustable- threshold 0.5uV |
Clarifier Range |
Coarse: +/- 5KHz Fine: +/- 1KHz (TX/RX) |
ANL |
Switchable |
Noise Blanker |
RF Type |
Audio Output Power |
4 Watts into 8 ohms Max. |
Audio Frequency Response |
300 to 2800 Hz |
Built-in Loudspeaker: |
8 ohms, 4W round |
External Loudspeaker (Not Supplied): |
8 ohms-, disable internal speaker when connected. |
