Cherokee Radios CBS2100
Ref.
Part Number
Description of Parts
Functional Description of Parts
Q261
TTR2SC945Q
25C945AQ
PA Tone Amplifier
Q701
TTR9013H-A
ST59013H
Driver for Channel display LED
Q703
KTC3876Y
KTC3876Y
Driver for PLL programmable divider
TR001
TTR2SC1675K
25C1675K
Noise Blanker RF amplifier
TR002
TTR2SC1675K
2SC1675K
TR003
TTR2SC945Q
2SC945AQ
TR004
TTR2SC945Q
2SC945AQ
AGC Control for Noise Blanker RF amplifier
TR005
TTR2SC945Q
2SC945AQ
Noise Blanker - Audio Noise amplifier
TR006
TTR2SA733P
2SA733P
TR007
TTR2SC945Q
2SC945AQ
Noise Blanker-IF Shunting transistor -
TR008
TTR2SC1674L
2SC1674L
Second IF Mixer
TR009
TTR2SC1675K
2SC1675K
455KHz IF Amplifier
TR010
TTR2SC1675K
2SC1675K
455KHz IFAmplifler
TR011
TTR2SC1675K
2SC1675K
455KHz IF Amplifier
TR012
TTR2SC945Q
2SC945AQ
AGC Attack time control in SSB Mode
TR013
TTR2SC945Q
2SC94EAQ
Signal meter adjustment - AM Mode
TR014
TTR2SC945Q
2SC94SAQ
Signal meter adjustment - SSB Mode
TR015
TTR2SC945Q
2SC945AQ
Audio amplifier for demodulated AM & Product detector for SSB
TR016
TTR2SC945Q
2SC945AQ
Switch - disable receiver audio
TR018
ETJ310
J310 (FET)
First IF Mixer
TR019
TTR2SC1674L
2SC1674L
558 IF Amplifier
TR020
TTR2SC1675K
2SC1675K
SSB IF Amplifier
TR021
TTR2SC1675K
2SC1675K
SSB IF Amplifier
TR022
TTR2SC1906
2SC1906
SSB IF Amplifier
TR023
TTR2SC945Q
2SC945AQ
Switch - AM Demodulator control
TR024
TTR2SC1675K
2SC1675K
10.24MHz Reference Frequency crystal oscillator
TR025
TTR2SC1675K
2SC1675K
PLL VCO
TR026
TTR2SC1675K
2SC1675K
PLL VCO
TR030
TTR2SC1675K
2SC1675K
Second offset frequency crystal oscillator
TR031
TTR2SC945Q
2SC945AQ
Switch - disable balanced modulator input in AM Mode
TR032
TTR2SC945Q
2SC945AQ
ALC audio shunting transistor
TR034
TTR2SA733P
2SA733P
Audio Detector for ALC operation
TR036
TTR2SA1282
2SA1262
Rx Active voltage control
TR037
TTR2SC945Q
2SC945AQ
TR038
TTR2SA1282
2SA1262
TX Active voltage control
TR040
TTR2SC945Q
2SC945AQ
8V Power supply regulator
TR041
TTR2SB1566E
2S81566E
TR042
TTR2SC945Q
2SC945AQ
Audio pre-amplifier for received audio
TR043
TTR2SC1989
2SC1969
RF Power Transistor
TR044
TTR25C2166C
2SC2166C
RF Power Driver
TR045
TTR2SC1973
2SC1973
RF Power Pre-Driver
TR046
TTR2SC1906
2SC1906
RF amplifier
TR047
TTR2SC1675K
2SC1675K
SSB Power level control
TR049
TTR2SC9450
2SC945AQ
AM RF Power control and AM Modulator
TR050
TTR2SA1282AE
2SA1262
TR051
TTR2SB754Y
2SB754Y
TR052
TTR2SC94SQ
2SC945AQ
Switch - disable AM Modulator for SSB operation
TR053
TTR2SC945Q
2SC945AQ
AM Modulation Control
TR060
TTR2SC9450
2SC945AQ
Frequency-Temperature Compensation Amplifier
TR061
FET3SK77GR
3SK77GR
Receiver front end amplifier
TR351
TTR2SC945Q
2SC945AQ
E.L Lamp Inverter Driver
TR401
TTR2SC945P
2SC945P
lnverter/1..ED Driver
TR801
TTR2SD467
2SD467
Logic Switch
TR802
TTR2SD467
2SD467
Logic Switch
TR803
TTR2SC945P
2SC945P
Logic Switch
TR804
TTR2SA562Y
2SA562
Logic Switch
TR901
TTR2SC945P
2SC945P
PA Bridge Amplifier
