Cobra
150GTL DX, 200GTL DX
Service Bulletins for the 150GTL DX and 200GTL DX
All the following file you will need to
You need to have Acrobat Reader version 5 or newer installed to view
Bulletin
Service Bulletin Description |
Models
How to add talkback. |
200GTL
DX
Receiver
overloads when receiving a strong signal, resulting in distorted audio. In addition there may be a warble in the modulation when transmitting (which the customer might describe as a popping sound during transmit). |
150GTL
DX |
Reduced adjacent channel rejection when the Noise Blanker is on. |
150GTL
DX
200GTL DX |
“Speed-up” the echo effect (add reverb). |
150GTL
DX
200GTL DX |
After adjusting the squelch control, sometimes received signals may sound choppy due to the squelch repeatedly opening and closing. |
150GTL
DX
200GTL DX |
The HF50-12F
MOSFET (Q35 and Q40) finals are no longer available. NOTE: HF50-12F is not a MOSFET it's a NPN Transistor. |
200GTL
DX
The frequency display is not accurate. |
200GTL
DX
