Galaxy DX Radios DX22B
CHASSIS PARTS DX-22B
Ref#
Description
MFR. Part No.
RL1
RELAY 9V
EX05N40802
Ref#
Description
MFR. Part No.
PTT P.C.B.
LEAD WIRE #28 200MM BROWN 5:05
WM0120005Z
POWER SW SDDFA3193A
EWPS33050X
C/F/R P-TYPE 47 OHM 1W P
RCP104704Z
C/C 0.022UF 50WV SL Z
CC0502237L
LAMP 5V 90mA
EX01N40080
SIGNAL METER P-55-8493
EX03N40403
ANT JACK
EX06N41029
ROTARY SW 6N
EWRT32043S
V/R 50KA
RV50303461
V/R 50KB/SW
RV50303462
T/F EI-86 110V/220V
ETP8620129
MICROPHONE ASS'Y BLACK DMC512-009
EX04N40620
LEAD WIRE #26 150MM BLACK 5:05
WL0015005Z
LEAD WIRE #26 150MM RED 5:05
WL0215005Z
LEAD WIRE #26 80MM BLACK 5:05
WL0008005Z
LEAD WIRE #26 200MM BROWN 5:05
WL0120005Z
WIRE CONNECTOR/H 6-6P
EX07N48503
WIRE CONNECTOR/H 2-2P
EX07N48505
WIRE CONNECTOR/H 2P L=180/160
EX07N48506
WIRE CONNECTOR/H 4-2-2P
EX07N48507
WIRE CONNECTOR/H 3-2P 2-3P
EX07N48508
WIRE CONNECTOR/H 2P L=200 PH 2.5
EX07N48510
EX07N48512
WIRE CONNECTOR/H 3-3P L=320PH=2.5
EX07N48513
WIRE CONNECTOR/H 3-3P L=160
EX07N48514
WIRE CONNECTOR/H 7-7P
EX07N48515
WIRE CONNECTOR/H 2P L=455 PH 2.5
EX07N48516
WIRE CONNECTOR/H 5-3-3P
EX07N48517
WIRE CONNECTOR/H 6-6P L=100
EX07N48518
WIRE CONNECTOR/H 3-3P L=230 PH=2.5
EX07N48519
WIRE CONNECTOR/H 6-3-3P
EX07N48520
WIRE CONNECTOR/H 4-2P
EX07N48522
WIRE CONNECTOR/H 7P-5P-2P
EX07N48796
WIRE CONNECTOR/H 5P-5P-2P
EX07N48797
WIRE CONNECTOR/H 3P L=380MM
EX07N48798
WIRE CONNECTOR/H 4P L=380MM
EX07N48799
EX07N48800
LEAD WIRE #18 130MM RED 5:05
WH0213005Z
LEAD WIRE #18 130MM WHITE 5:05
WH0913005Z
LEAD WIRE #18 220MM RED 5:05
WH0222005Z
LEAD WIRE #18 250MM RED 5:05
WH0225005Z
LEAD WIRE #18 250MM YELLOW 5:05
WH0425005Z
LEAD WIRE #18 250MM WHITE 5:05
WH0925005Z
LEAD WIRE #18 510MM RED 5:05
WH0251005Z
COAXIAL CABLE 200mm 50 OHM
WX03830200
COAXIAL CABLE 1.5D-2VG2.9MM 120MM BLACK
WX03001012
LEAD WIRE #22 190MM ORANGE 5:05
WJ0319005Z
RUBBER KEY PANEL
PTTURB010A
REFLECTOR PLATE
PTTURB020A
DISPLAY WINDOW
PTTURB030A
GLASS WINDOW HOLDER
PT0SSB010A
PLASTIC FOOT
PT0SSB040A
METER BACK COVER
PT0SSB070A
ACRY WINDOW
PT0SSB092A
KNOB WASHER
PT3600090A
Ref#
Description
MFR. Part No.
REFRACTOR PLATE
PT2950041A
HOLDER OF METER
MTTURB110X
CHANNEL KNOB
MTTURB140D
PUSH BUTTON
MTTURB150A
MIC BRACKET
MT0SSB170N
INDICTOR NAME���� PLATE
MT0SSB101K
VR KNOB���������� 18Q BLACK
MT0SSB161B
TOP COVER�������� BLACK
MT0SSB010B
BOTTOM PLATE
MT0SSB021S
RIGHT SIDE BRACKET
MT0SSB071S
LEFT SIDE BRACKET
MT0SSB081S
HANDLE ASSEMBLY
MT0SSB120B
HANDLE ASSEMBLY
MT0SSB130B
HANDLE BRACKET
MT0SSB141S
HEAT SINK COVER
MT0SSB310X
SUPPORTER OF P.T.
MT0SSB360X
FIXED PLATE������ (PT)
MT0SSB371X
ECHO PCB
PCB BRACKET
MT3001010S
HEAT SINK C
MM5500100X
RUBBER WASHER
QT0SSB030A
RUBBER KEY
QT2950010A
EARPHONE COVER
QM5500030A
TOP COVER
SHIELD CLOTH A 200x10x0.5t
LZZZ60018Z
SPEAKER
SHIELD CLOTH (C) 106x90x0.5t
LZZZ60020Z
FEET
WASHER(FOR FOOT) 25x9x4t
LZZZ60021Z
BOTTOM COVER
CAUTION LABEL
LZZZ61066Z
CAUTION LABEL
LZZZ61515Z
CAUTION LHEET
LZZZ61516Z
2166
INSULATING RING
XZZZ90003Z
2312x2
INSULATING RING
XZZZ90003Z
473
INSULATING RING
XZZZ90003Z
8A
INSULATING PLATE 18x13mm
XZZZ90020Z
INSULATING PLATE 10x14x1.55m
XZZZ90358Z
METER
FOAM 40x8x2
XZZZ90061Z
BUZZER
SPONGE 22x1.5t
XZZZ90206Z
FOAM 10x15x4.5
XZZZ90091Z
2SD797(1)
SOLDER PLATE 3.2mm
XZZZ90002Z
POWER PCB(1)
SOLDER PLATE 3.2mm
XZZZ90002Z
PLATE(1)
SOLDER PLATE 3.2mm
XZZZ90002Z
2SD797
INSULATING RING (TO-220D)
XZZZ90316Z
WASHER 6x7x10.8t
XZZZ90057Z
FOR PCB
FOAM 14x16x20mm
XZZZ90004Z
SPONGE D 30x53x6t
XZZZ90078Z
SPONGE RUBBER 108x25x1t
XZZZ90205Z
CLAMP
GZZZ50000Z
FUSE HOLDER�� ����HFH-004
GZZZ50049Z
2SD797
SET SCREW M3x0.5Px12
JS053012MN
SET SCREW M4x0.7Px12
JS114012MQ
HANDLE
SET SCREW M5x0.8Px12
JS035012MB
FRONT PLATE
SET SCREW M3x0.5Px6
JS033006MN
HANDLE(4)
JS055012MB
TOP COVER(4)
JS055012MB
PCB CHASSIS(4)
SET SCREW M4x0.7Px8
JS054008MS
EARPHONE(2)
SET SCREW M3x0.5Px8
JS053008MB
Ref#
Description
MFR. Part No.
IC(4)
SET SCREW M2x0.4Px12
JS052012MN
473(1)
JS052012MN
SET SCREW M3X0.5PX6 W/S/W
JS013006SN
HEAT SINK(4)
SET SCREW M3X0.5PX8 W/S/W
JS053008SN
SET SCREW T3x8-2
JS053008TB
HEAT SINK(4)
SET SCREW W3.2x8-1
JS053208WB
ANT(3)
SET SCREW T3x8-2
JS053008TH
SPEAKER(4)
SET SCREW T3.5x8-2
JS053508TH
PLATE(1)
SET SCREW T3.5x8-2
JS053508TH
FEET(4)
SET SCREW T3x14-2
JS013014TH
SET SCREW T3x8-2 STEEL
JS013008TH
IC TA7222
SET SCREW M3x0.5Px6
JS013006MV
PT
SET SCREW M4x0.7Px10
JS054010MS
ECHO P.C.B.
SET SCREW M3x0.5Px6
JS053006MN
2SD797
NUT M3x2.4t
JN243024ZS
PT
M4X0.7P LOCK NUT
JN284007ZN
EAR PHONE
INSULATE WASHER 6QX11.5X0.5T
JW306011EY
SET (TOP COVER)x4
WASHER (BLACK) 5.3x12x0.8t
JW305312FB
HANDLE(4)
JW305312FB
SPRING WASHER 4x6x1t
JW344006GN
PCB(5)
IN-TOOTH WASHER 3Q
JW323006DN
NUT WITH WASHER M3x3.5t
JN263035ZS
FEET
WASHER 4Qx9x0.8
JW304009FS
OUT-TOOTH WASHER 5.5x10x0.3tmm
JW315510CN
SET SCREW W5x10-1
JS015010WH
FUSE 125V 5A
EX02N40214
MIC STOPPER
XZZZ90008Z
Copyright © 2003 CBTricks.com
