Galaxy
DX Radios DX22B
CPU P.C.B. DPT295042Z
Ref#
Description |
MFR.
Part No.
CPU P.C.B. DPT295042Z |
#T-106O-P03
CPU P.C.B. |
DPT295042Z
Capacitors
Ref#
Description |
MFR.
Part No.
C601 |
CHIP/C (SMD) 33PF 50WV J CH |
CK1330AB4A |
C602 |
CHIP/C (SMD) 1UF 16WV Z Y5V |
CK5105AB7R |
C603 |
CK5105AB7R |
C604 |
E/C 220UF 10WV Z |
CE0102277Z |
C605 |
CHIP/C (SMD) 0.1UF 50WV Z F Y5V |
CK1104AB7R |
C606 |
CHIP/C (SMD) 56PF 50WV J CH |
CK1560AB4A |
C607 |
CHIP/C (SMD) 0.22UF 50WV Z Y5V |
CK1224AB7R |
C608 |
CHIP/C (SMD) 0.001UF 50WV Z SL |
CK1102AB7L |
C609 |
CK1102AB7L |
C610 |
CK1104AB7R |
C611 |
CK1104AB7R |
C612 |
CK1104AB7R |
C613 |
CK1104AB7R |
C614 |
CK1104AB7R |
C615 |
CK1104AB7R |
C616 |
CK1104AB7R |
C617 |
CK1104AB7R |
Resistors
Ref#
Description |
MFR.
Part No.
CHIP/F/R (SMD) 100 OHM 0.1W |
RCY011014Z |
R601 |
CHIP/F/R (SMD) 10K OHM 0.1W |
RCY011034Z |
R602 |
CHIP/F/R (SMD) 1M OHM 0.1W |
RCY011054Z |
R603 |
RCY011034Z |
R604 |
C/F/R F-TYPE 82 OHM 1/2W |
RCU128204Z |
R605 |
CHIP/F/R (SMD) 8.2K OHM 0.1W |
RCY018224Z |
R606 |
C/F/R 56 OHM 1/2W U |
RCU125604Z |
R607 |
CHIP/F/R (SMD) 4.7K OHM 0.1W |
RCY014724Z |
R608 |
CHIP/F/R (SMD) 470K OHM 0.1W |
RCY014744Z |
R609 |
CHIP/F/R (SMD) 47K OHM 0.1W |
RCY014734Z |
R610 |
RCY011034Z |
R611 |
RCY011034Z |
R612 |
RCY014734Z |
R613 |
RCY014734Z |
R614 |
CHIP/F/R (SMD) 100K OHM 0.1W |
RCY011044Z |
R615 |
CHIP/F/R (SMD) 56K OHM 0.1W |
RCY015634Z |
R616 |
CHIP/F/R (SMD) 27K OHM 0.1W 5% |
RCY012734Z |
R617 |
RCY015634Z |
R618 |
RCY012734Z |
R619 |
RCY015634Z |
R620 |
RCY012734Z |
R621 |
RCY015634Z |
R622 |
RCY015634Z |
R623 |
RCY012734Z |
R624 |
RCY012734Z |
R625 |
RCY015634Z |
R626 |
RCY015634Z |
R627 |
RCY011034Z |
R628 |
RCY014734Z |
R629 |
CHIP/F/R (SMD) 33K OHM 0.1W |
RCY013334Z |
R630 |
CHIP/F/R (SMD) 150K OHM 0.1W |
RCY011544Z |
R631 |
RCY011034Z |
Integrated Circuits
Ref#
Description |
MFR.
Part No.
U601 |
I.C. (RANGER) 80PIN HD404818E14FS |
YNRG2951SP |
U602 |
I.C. (MATSU)(SMD) AN8005M-E2 3PIN |
YNMA08005M |
U604 |
I.C. (SMD) BU4094BF 16 PIN |
YNRO04094B |
U605 |
YNRO04094B |
U606 |
I.C. (SMD) (EXEL) XL93LC46P 8PIN |
YNEX93L46P |
Transistors
Ref#
Description |
MFR.
Part No.
Q602 |
T/R (SMD) 2SD999-TP |
TY2SD0999Z |
Q603 |
T/R (SMD) 2SC2712GR-TE85L |
TY2SC2712G |
Q604 |
TY2SD0999Z |
Q605 |
TY2SC2712G |
Q606 |
TY2SC2712G |
Q607 |
TY2SC2712G |
Diodes
Ref#
Description |
MFR.
Part No.
D601 |
DIODE (SMD) 1SS355 |
EDSS00355Y |
D602 |
EDSS00355Y |
D603 |
EDSS00355Y |
Display
Ref#
Description |
MFR.
Part No.
DISPLAY |
LCD DISPLAY MT-628PAT |
EX03N40460 |
Resonator
Ref#
Description |
MFR.
Part No.
X601 |
CERAMIC RESONATOR 4.0MHz |
EX14N46510 |
Buzzer
Ref#
Description |
MFR.
Part No.
BZ601 |
BUZZER PKM17EW-4000 |
EX14N46511 |
Lamps
Ref#
Description |
MFR.
Part No.
LP601 |
LAMP 5V 90mA |
EX01N40080 |
LP602 |
LAMP 5V 90mA |
EX01N40080 |
Connectors
Ref#
Description |
MFR.
Part No.
CN601 |
PCB CONNECTOR/S 4P T PH=2.5 |
EX07N41250 |
CN602 |
PCB CONNECTOR/S 2P PH=2.5 |
EX07N41226 |
CN603 |
PCB CONNECTOR/S 3P T PH=2.5 |
EX07N41216 |
CN604 |
EX07N41216 |
CN605 |
EX07N41216 |
CN608 |
EX07N41226 |
CN610 |
EX07N41216 |
SK601 |
PCB CONNECTOR/S 6P L TYPE |
EX07N41280 |
SK602 |
PCB CONNECTOR/S 6P T PH=2.5 |
EX07N41266 |
JP601 |
PCB CONNECTOR/S 4P |
EX07N48440 |
J602(J5) |
EX07N48440 |
SHORT1 |
PCB CONNECTOR/H SHORT PIN (2P) |
EX07N48151 |
SHORT2(J5) |
EX07N48151 |
