Galaxy DX Radios DX22B
ROBOT / ECHO P.C.B. EPT0SSB50C
Trace Layout
Ref#
Description
MFR. Part No.
ECHO P.C.B. Complete with Components
#T-106O-P06
ECHO P.C.B. 80x48x1.6tmm(S)
EPT0SSB50C
Ref#
Description
MFR. Part No.
R2
CHIP/F/R (SMD) 4.7K OHM 0.1W
RCY014724Z
R3
CHIP/F/R (SMD) 15K OHM 0.1W 5%
RCY011534Z
R4
CHIP/F/R (SMD) 18K OHM 0.1W
RCY011834Z
R5
RCY014724Z
R6
CHIP/F/R (SMD) 39K OHM 0.1W
RCY013934Z
R7
RCY011534Z
R8
CHIP/F/R (SMD) 1K OHM 0.1W
RCY011024Z
R9
CHIP/F/R (SMD) 2.2K OHM 0.1W
RCY012224Z
R10
CHIP/F/R (SMD) 10K OHM 0.1W
RCY011034Z
R11
RCY011034Z
R16
RCY011034Z
R18
CHIP/F/R (SMD) 22K OHM 0.1W
RCY012234Z
R19
RCY011034Z
R20
RCY011534Z
R21
CHIP/F/R (SMD) 3.3K OHM 0.1W
RCY013324Z
R23
RCY011534Z
R24
RCY011034Z
R25
RCY011534Z
R26
CHIP/F/R (SMD) 8.2K OHM 0.1W
RCY018224Z
R27
CHIP/F/R (SMD) 82K OHM 0.1W
RCY018234Z
R28
RCY018224Z
R29
RCY018234Z
R30
C/F/R P-TYPE 10K OHM 1/4W P
RCP141034Z
R31
CHIP/F/R (SMD) 100K OHM 0.1W
RCY011044Z
R33
CHIP/F/R (SMD) 0 OHM 0.1W
RCY010004Z
R34
RCY010004Z
R35
RCY010004Z
R37
RCY014724Z
R38
RCY011034Z
R39
RCY011034Z
R40
RCY011034Z
R41
RCY011024Z
R42
RCY011034Z
R43
RCY011024Z
R44
RCY011534Z
R50
RCY010004Z
R51
RCY011044Z
R52
RCY010004Z
R53
CHIP/F/R (SMD) 10 OHM 0.1W
RCY011004Z
R54
RCY010004Z
R55
RCY010004Z
R61
RCY010004Z
R62
RCY010004Z
R63
RCY010004Z
R65
CHIP/F/R (SMD) 47K OHM 0.1W
RCY014734Z
R66
RCY010004Z
R67
RCY011044Z
R68
CHIP/F/R (SMD) 470 OHM 0.1W
RCY014714Z
R69
RCY010004Z
VR1
RCY011044Z
Ref#
Description
MFR. Part No.
C1
CHIP/C (SMD) 0.22UF 50WV Z Y5V
CK1224AB7R
C2
CHIP/C (SMD) 0.001UF 50WV Z SL
CK1102AB7L
C3
CK1224AB7R
C4
CHIP/C (SMD) 560P 50WV K CH
CK1561AB5A
C5
CHIP/C (SMD) 0.1UF 25WV Z Y5V
CK2104AB7R
C7
CHIP/C (SMD) 1UF 16WV Z Y5V
CK5105AA7R
C9
CHIP/C (SMD) 0.01UF 50WV M Z5U
CK1103AB6U
C10
E/C 47UF 16WV Z
CE0164767Z
C11
CK5105AA7R
C12
CK1103AB6U
C13
CK2104AB7R
C14
CK1224AB7R
C15
CK1103AB6U
C17
CK5105AA7R
C18
CK1102AB7L
C19
CK1103AB6U
C22
CK2104AB7R
C23
CK5105AA7R
C24
CHIP/C (SMD) 0.0056UF50WV Z Y5V
CK1562AB7R
C25
CK1561AB5A
C26
CHIP/C (SMD) 0.033UF 50WV M Z5U
CK1333AB6U
C27
CK1561AB5A
C28
CHIP/C (SMD) 0.047UF 50WV Z Y5V
CK1473AB7R
C29
CK1562AB7R
C30
CK1224AB7R
C31
CK1473AB7R
C32
CK1103AB6U
C33
CK1224AB7R
C34
CK1103AB6U
C35
CK1103AB6U
C36
CK2104AB7R
C37
CK5105AA7R
C38
CK2104AB7R
C39
CK1103AB6U
C40
CK1103AB6U
C41
E/C 47UF 16WV Z
CE0164767Z
C42
CK1224AB7R
C43
CK1103AB6U
C44
CK1103AB6U
C45
CHIP/C (SMD) 5PF 50WV C CH
CK1050AB1A
C50
CK1103AB6U
C63
CK1103AB6U
C64
CK1103AB6U
C65
CK1103AB6U
C68
E/C 470UF 10WV Z
CE0104777Z
VC1
TRIMMER/C 20PF (CV38D2001)
CV038200AZ
Ref#
Description
MFR. Part No.
IC1
I.C. (SMD) NJM4558M 8PIN
YNJR04558M
IC2
I.C. (SMD) ES56028S 28PIN
YNES56028S
IC3
I.C. RTS0072 16PIN
ENRE00072Z
Ref#
Description
MFR. Part No.
Q1
T/R (SMD) 2SD999-TP
TY2SD0999Z
Q2
T/R (SMD) RN2403-TE85L
TYZRN2403Z
Q3
T/R (SMD) RN1403-TE85L
TYZRN1403Z
Ref#
Description
MFR. Part No.
D1
ZENER DIODE 5.6V (SMD)
EDZD05569Y
D2
DIODE (SMD) 1N4148
ED1N04148Y
D3
DIODE (SMD) 1N4148
ED1N04148Y
D4
DIODE (SMD) 1SS355
EDSS00355Y
D5
DIODE (SMD) 1SS355
EDSS00355Y
D6
DIODE (SMD) 1SS355
EDSS00355Y
D7
DIODE (SMD) 1SS355
EDSS00355Y
D8
DIODE (SMD) 1SS355
EDSS00355Y
D9
DIODE (SMD) 1SS355
EDSS00355Y
D10
DIODE (SMD) 1SS355
EDSS00355Y
D11
DIODE (SMD) 1N4148
ED1N04148Y
Ref#
Description
MFR. Part No.
J1
PCB CONNECTOR/S 2P PH=2.5
EX07N41226
J2
PCB CONNECTOR/S 3P T PH=2.5
EX07N41216
J3
EX07N41216
J5
EX07N41216
J6
PCB CONNECTOR/S 4P T PH=2.5
EX07N41250
J7
EX07N41226
J8
EX07N41216
J9
JUMPER WIRE 7X9MMX7
WX01070709
ECHO/
TIME
PCB CONNECTOR/S 5P T PH=2.5
EX07N40038
Ref#
Description
MFR. Part No.
JP1
JUMPER WIRE 7x20x7
WX01070720
JP2
JUMPER WIRE 7x12x7
WX01070712
JP3
JUMPER WIRE 7x22x7
WX01070722
JP4
JUMPER WIRE 7x22x7
WX01070722
JP6
JUMPER WIRE 7x10x7
WX01070710
JP7
JUMPER WIRE 7x12x7
WX01070712
JP8
JUMPER WIRE 7x12x7
WX01070712
JP10
JUMPER WIRE 7x10x7
WX01070710
Copyright © 2003 CBTricks.com
