Galaxy DX Radios DX2517
MODULAR VCO P.C.B. (EPF000210Z)
Trace Layout
Schematic
Resistors
Ref#
Description
MFR. Part No.
R1
CHIP/F/R (SMD) 10 OHM 0.1W
RCY011004Z
R2
CHIP/F/R (SMD) 10K OHM 0.1W
RCY011034Z
R3
CHIP/F/R (SMD) 100 OHM 0.1W
RCY011014Z
R4
RCY011034Z
R5
RCY011034Z
R6
CHIP/F/R (SMD) 560 OHM 0.1W
RCY015614Z
CHIP/F/R (SMD) 6.5K OHM 0.1W
RCY016534Z
R7
RCY011034Z
R8
CHIP/F/R (SMD) 47K OHM 0.1W
RCY014734Z
R9
CHIP/F/R (SMD) 220K OHM 0.1W
RCY012244Z
R10
RCY011004Z
Capacitors
Ref#
Description
MFR. Part No.
C1
T/C(SMD) 'A'CASE 1UF 16WV M
CTY161056Z
C2
CHIP/C (SMD) 0.01UF 50WV K X7R
CK1103AB5X
C3
CHIP/C (SMD) 220PF 50WV K UJ K CH
CK1221AB5G
C4
CHIP/C (SMD) 180PF 50WV K SL K CH
CK1181AB5L
C5
CHIP/C (SMD) 10PF 50WV D CH
CK1100AB2A
C6
CK1100AB2A
C7
CHIP/C (SMD) 18PF 50WV J CH
CK1180AB4A
C8
CHIP/C (SMD) 470PF 50WV K CH
CK1471AB5A
C9
CHIP/C (SMD) 5PF 50WV C SL CH
CK1050AB1L
C10
CHIP/C (SMD) 0.001UF 50WV K X7R
CK1102AB5X
C11
CK1102AB5X
Transistors
Ref#
Description
MFR. Part No.
Q1
TRANSISTOR (SMD) 2SC2712GR-TE85L
TY2SC2712G
Q2
TRANSISTOR (SMD) 2SC3123 -TE85L
TY2SC3123Z
Q3
TY2SC3123Z
Diodes
Ref#
Description
MFR. Part No.
D1
DIODE (SMD) 1SV214 -TP
ED1V00214Y
D2
DIODE (SMD) HVU359
EDHU00359Y
D3
DIODE (SMD) HVU359
EDHU00359Y
Hardware
Ref#
Description
MFR. Part No.
IC PIN 022-1.0-S(WAKO)
GZZZ50098Z
Copyright © 2002 CBTricks.com
