Galaxy
DX Radios DX2517
Chassis, Miscellaneous & Mechanical Parts
Ref# |
Description |
MFR. Part No. |
GLASS WINDOW HOLDER |
PT0SSB010A |
PLASTIC FOOT |
PT0SSB040A |
LEVEL SW COVER |
PT0SSB060A |
METER BACK COVER |
PT0SSB070A |
SW KNOB BLACK |
PT0SSB080B |
ACRY WINDOW |
PT0SSB092A |
LED WINDOW DX-2517 |
PT0SSB110B |
LED WINDOW(B) |
PT0SSB120A |
KNOB WASHER |
PT3600090A |
MICA INSULATOR TO-3 |
PA0100010A |
TOP COVER BLACK |
MT0SSB010B |
BOTTOM PLATE |
MT0SSB021S |
FRONT CHASSIS |
MT0SSB035X |
BAND |
FRONT PANEL DX-2517 |
MT0SSB042W |
RIGHT SIDE BRACKET |
MT0SSB071S |
LEFT SIDE BRACKET |
MT0SSB081S |
HANDLE ASSEMBLY BLACK |
MT0SSB120B |
MT0SSB130B |
HANDLE BRACKET |
MT0SSB141S |
CHANNEL KNOB |
MT0SSB150B |
MIC BRACKET |
MT0SSB170N |
2N3055 |
HEAT SINK COVER |
MT0SSB310X |
DUAL KNOB (A) |
MT0SSB320A |
DUAL KNOB (B) |
MT0SSB330A |
HEAT SINK C |
MM5500100X |
BACK PANEL |
MT0SSB272A |
MAIN PCB CHASSIS |
MT0SSB296X |
B/G |
HEAT SINK E |
MT0SSB305X |
HEATSINK D |
MT0SSB252B |
SHEILD PLATE |
MT0SSB430X |
INDICTOR NAME PLATE |
MT0SSB101K |
DISPLAY & INDICATOR CHASSIS |
MT0SSB111S |
VR KNOB BLACK |
MT0SSB161B |
SUPPORTER OF P.T. |
MT0SSB360X |
FIXED PLATE |
MT0SSB371X |
PUSH BUTTON |
MTTURB150A |
DFB, |
PCB BRACKET |
MT3001010S |
51ZPCB |
PCB BRACKET |
MT3001010S |
MIC PLATE GALAXY |
BA0112010A |
METER |
LAMP STOPPER |
QT0SSB020A |
EARPHONE COVER |
QM5500030A |
-90Z PCB |
HEXANGULAR SCREW M3x0.5Px17mm |
MD0360041X |
COUNTER USE |
SPONGE 22x15x4tmm |
XZZZ90367A |
DISPLAY-CONNTER PCB |
HEX SPACER (CBS-5A) |
GZZZ50182Z |
TOP COVER |
SHIELD CLOTH (A) 200x10x0.5t |
LZZZ60018Z |
SW |
SHIELD CLOTH (B) 32x15x0.5t |
LZZZ60019Z |
SPEAKER |
SHIELD CLOTH (C) 106x90x0.5t |
LZZZ60020Z |
FEET |
WASHER (FOR FOOT) 25x9x4t |
LZZZ60021Z |
METER |
FOAM 14x14x2 |
XZZZ90053Z |
METER |
FOAM 40x8x2 |
XZZZ90061Z |
MOR PCB |
FOAM 14x16x20mm |
XZZZ90004Z |
SWR PCB |
FOAM 14x16x20mm |
XZZZ90004Z |
INSULATING PLATE 18x13mm |
XZZZ90020Z |
2166, |
INSULATING RING |
XZZZ90003Z |
2312x2 |
INSULATING RING |
XZZZ90003Z |
2166(1) |
INSULATING PLATE 10x14x1.55mm |
XZZZ90358Z |
2312(2) |
XZZZ90358Z |
ANT A(1) |
SOLDER PLATE 3.2mm |
XZZZ90002Z |
2SD797(1) |
XZZZ90002Z |
PLATE(1) |
XZZZ90002Z |
EARPHONE |
WASHER 6x7x10.8t |
XZZZ90057Z |
2SD797 |
INSULATING RING (TO-220D) |
XZZZ90316Z |
BOTTOM COVER |
CAUTION LABEL |
LZZZ61066Z |
FIBER PLATE |
XZZZ90319Z |
CORD BUSHING SR-5R1 |
GZZZ50168Z |
CLAMP GT-100M |
GZZZ50000Z |
FUSE HOLDER FH-004 |
GZZZ50049Z |
SET (POLYLON & GIFT BOX) |
PVC BAG 600x410x830x0.07t |
UB07604183 |
SET |
PVC BAG 500x190x740x0.07t |
UB07501974 |
I/M |
PVC BAG 220x360x0.05tmm |
UB052236ZZ |
POLYLON RIGHT LEFT |
UPT0SSB01M |
CARTON DX-2517 |
UCT0SSBA1W |
G/B DX-2517 |
UGT0SSBA1W |
I/M DX-2517 |
AT0SSB010W |
SET SCREW M4x0.7Px12 |
JS114012MQ |
HANDLE(4) |
SET SCREW M5x0.8Px12 |
JS035012MB |
FRONT PLATE(3) |
SET SCREW M3x0.5Px6 |
JS033006MN |
HANDLE (4) |
JS055012MB |
TOP COVER(4) |
JS055012MB |
PCB CHASSIS (4) |
SET SCREW M4x0.7Px8 |
JS054008MS |
EARPHONE(2) |
SET SCREW M3x0.5Px8 |
JS053008MB |
SET SCREW M3x0.5Px10 |
JS053010MN |
IC(3) |
SET SCREW M2x0.4Px12 |
JS052012MN |
437(1) |
JS052012MN |
HEAT SINK(4) |
SET SCREW M3X0.5PX8 |
JS053008SN |
W/S/W 4 |
JS053008SN |
BACK PANEL(9) |
SET SCREW T3x8-2 |
JS053008TB |
INDICATOR |
SET SCREW T3x8-2 |
JS053008TB |
HEAT SINK(4) |
SET SCREW W3.2x8-1 |
JS053208WB |
ANT(3) |
SET SCREW T3x8-2 |
JS053008TH |
SPEAKER(4) |
SET SCREW T3.5x8-2 |
JS053508TH |
FEET(4) |
SET SCREW T3x14-2 |
JS013014TH |
LED(1) |
SET SCREW T3x8-2 STEEL 50 |
JS013008TH |
FRONT PLATE(2) |
JS013008TH |
ECHO (2) |
JS013008TH |
BOTTOM(8) |
JS013008TH |
BRACKET(12) |
JS013008TH |
PCB(09) |
JS013008TH |
DISPLY BRACKET(6 |
JS013008TH |
SPARE PARTS(3) |
JS013008TH |
BACK COVER (9) |
JS013008TH |
RECIFITER(1) | SET SCREW M3x0.5Px18 |
JS033018MN
IC TA7222(1) |
JS013008MV |
SW(2) W/S/W 2 |
SET SCREW M3X0.5PX6 |
JS013006SN |
MAIN PCBx5 |
SCREW T3x6-2 |
JS053006TH |
LEVER SWx5 |
SCREW T3x6-2 |
JS053006TH |
MIC SOLDER PLATEx1 |
SCREW T3x6-2 |
JS053006TH |
ECHO PCB(2) |
JS053006MN |
M4X0.7P LOCK NUT |
JN284007ZN |
2SD797 |
SET SCREW M3x0.5Px12 |
JS053012MN |
TR41 |
SET SCREW M2x0.4Px6 |
JS052006MN |
EAR PHONE |
INSULATE WASHER 6QX11.5X0.5T |
JW306011EY |
SPRING WASHER 4x6x1t |
JW344006GN |
SET (TOP COVER)(4) |
WASHER 5.3x12x0.8t (BLACK) |
JW305312FB |
HANDLE (4) |
JW305312FB |
PCB(5) |
IN-TOOTH WASHER 3Q |
JW323006DN |
NUT WITH WASHER M3x3.5t |
JN263035ZS |
FEET |
WASHER 4Qx9x0.8 |
JW304009FS |
NUT M3x2.4t |
JN243024ZS |
BOX FOR SPARE PART 90x50x120 |
UWT0SSB01A |
SPARE PARTS |
PVC BAG 100x150x0.05tmm |
UB051015ZZ |
OUT-TOOTH WASHER 5.5x10x0.3tmm |
JW315510CN |
IN-TOOTH WASHER 4x8x0.3tmm |
JW324008CN |
SET SCREW W5x10-1 |
JS015010WH |
MIC STOPPER |
XZZZ90008Z |
FUSE 125V 5A |
EX02N40214 |
