Galaxy DX Radios DX2517 (MOSFET Final)
ANF P.C.B. EPT360080Z
Schematic Diagram
Schematic Diagram
Ref#
Description
MFR. Part No.
ANF P.C.B.�EPT360080Z
ANF P.C.B.
EPT360080Z
Ref#
Description
MFR. Part No.
R1
C/F/R 15K OHM 1/4W U
RCU141534Z
R2
RCU141534Z
R3
C/F/R 10K OHM 1/4W U
RCU141034Z
R4
RCU141034Z
R5
RCU141034Z
R6
RCU141034Z
R7
RCU141034Z
R8
RCU141034Z
R9
RCU141034Z
R10
C/F/R 10 OHM 1/4W U
RCU141004Z
R11
C/F/R 270 OHM 1/4W U
RCU142714Z
R12
C/F/R 27K OHM 1/4W U
RCU142734Z
R13
C/F/R 100 OHM 1/4W U
RCU141014Z
R14
RCU141034Z
R15
C/F/R 100K OHM 1/4W U
RCU141044Z
R16
RCU141044Z
Ref#
Description
MFR. Part No.
C1
M/C 0.022UF 50WV K
CM0502235Z
C2
M/C 0.022UF 50WV K
CM0502235Z
C3
M/C 0.022UF 50WV K
CM0502235Z
C4
CHIP/C 0.01UF 50WV M
CH0501036A
C5
M/C 0.022UF 50WV K
CM0502235Z
C6
M/C 0.022UF 50WV K
CM0502235Z
C7
M/C 0.022UF 50WV K
CM0502235Z
C9
M/C 0.022UF 50WV K
CM0502235Z
C10
C/C 560PF 50WV SL K
CC0505615L
C11
CHIP/C 0.0047UF 50WV M
CH0504726A
C12
CH0504726A
C13
M/C 0.001UF 50WV K
CM0501025Z
C14
M/C 0.0022UF 50WV K
CM0502225Z
C15
M/C 0.022UF 50WV K
CM0502235Z
C17
CH0504726A
C18
M/C 0.01UF 50WV K
CM0501035Z
C19
E/C 47UF 16WV Z
CE0164767Z
C20
C/C 0.1UF 50WV SL Z
CC0501047L
Ref#
Description
MFR. Part No.
IC1
I.C. (JRC) NJM324D 14PIN
ENJR00324D
Ref#
Description
MFR. Part No.
J4
PCB CONNECTOR/S 6P T PH=2.5 (WHITE)
EX07N41344
Ref#
Description
MFR. Part No.
J1
JUMPER WIRE 7x5MMx7
WX01070705
J2
JUMPER WIRE 7x4MMx7
WX01070704
J3
JUMPER WIRE 7x6MMx7
WX01070706
Copyright © 2007 CBTricks.com
