Galaxy
DX Radios DX2517 (MOSFET
Final)
Frequency
Counter PCB (EPT900043Z)
Trace
Layout
Schematic Diagram
(Mar. 04, 2005)
FC-2004(VR DIM B) COUNTER
COUNTER PCB 62x34.5x1.6tmm (d) EPT900043Z
Ref#
Description |
MFR.
Part No.
R1 |
CHIP/F/R (SMD) 0 OHM 0.1W |
RCY010004Z |
R2 |
CHIP/F/R (SMD) 47 OHM 0.1W |
RCY014704Z |
R3 |
CHIP/F/R (SMD) 10K OHM 0.1W |
RCY011034Z |
R4 |
CHIP/F/R(SMD) 4.7K OHM 0.1W |
RCY014724Z |
R5 |
RCY014724Z |
R6 |
CHIP/F/R (SMD) 330 OHM 0.1W |
RCY013314Z |
R7 |
RCY011034Z |
R8 |
RCY011034Z |
R9 |
RCY011034Z |
R10 |
CHIP/F/R (SMD) 100 OHM 0.1W |
RCY011014Z |
R11 |
RCY011034Z |
R12 |
RCY013314Z |
R13 |
RCY011034Z |
R14 |
CHIP/F/R (SMD) 1K OHM 0.1W |
RCY011024Z |
R15 |
CHIP/F/R (SMD) 39K OHM 0.1W |
RCY013934Z |
R16 |
RCY014704Z |
R17 |
RCY013314Z |
R18 |
CHIP/F/R (SMD) 220 OHM 0.1W |
RCY012214Z |
R19 |
CHIP/F/R (SMD) 1M OHM 0.1W |
RCY011054Z |
R20 |
CHIP/F/R (SMD) 100K OHM 0.1W |
RCY011044Z |
R21 |
RCY011014Z |
R22 |
RCY011014Z |
R23 |
RCY011014Z |
R24 |
RCY011014Z |
R25 |
RCY011014Z |
R26 |
RCY011014Z |
R27 |
RCY011014Z |
R28 |
RCY011014Z |
R29 |
RCY011014Z |
R30 |
RCY011014Z |
R31 |
RCY011014Z |
R32 |
RCY011014Z |
R33 |
RCY011014Z |
R34 |
RCY011014Z |
R35 |
RCY011014Z |
R36 |
RCY011014Z |
R37 |
RCY011014Z |
R38 |
RCY011014Z |
R39 |
RCY011014Z |
R40 |
RCY011014Z |
R41 |
RCY011014Z |
R43 |
RCY011034Z |
R44 |
RCY011034Z |
R45 |
RCY011034Z |
R46 |
RCY011024Z |
Ref#
Description |
MFR.
Part No.
C1 |
E/C 100UF 16WV H=5mm |
CEM161077A |
C2 |
CHIP/C 0.1UF 50WV Z F Y5V |
CK1104AB7R |
C3 |
CK1104AB7R |
C4 |
CK1104AB7R |
C5 |
CEM161077A |
C7 |
CHIP/C 0.01UF 50WV M Z5U |
CK1103AB6U |
C8 |
CK1103AB6U |
C9 |
CK1103AB6U |
C10 |
CEM161077A |
C11 |
CK1103AB6U |
C12 |
CK1103AB6U |
C13 |
CK1104AB7R |
C14 |
CK1103AB6U |
C15 |
CK1103AB6U |
C16 |
CEM161077A |
C17 |
CHIP/C 15PF 50WV J CH |
CK1150AB4A |
C19 |
CK1104AB7R |
C20 |
CK1103AB6U |
C21 |
CK1104AB7R |
C22 |
CK1104AB7R |
C23 |
CK1104AB7R |
C24 |
CK1104AB7R |
C25 |
CK1104AB7R |
C26 |
CK1104AB7R |
C27 |
CK1104AB7R |
Ref#
Description |
MFR.
Part No.
VC1 |
TRIMMER/C (SMD) 20PF 3.8p |
CV038200AY |
Ref#
Description |
MFR.
Part No.
IC1 |
I.C. NJM78L05UA-TE1 (JRC) (SMD)� 3P |
YNJR78L05Z |
IC2 |
I.C. 74HC161D (PHILIPS) (SMD) 16PIN |
YNPHHC161D |
IC3 |
I.C. HT48R50A-48 (SMD) (RANGER) 48PIN |
YNRGFC04SP |
Ref#
Description |
MFR.
Part No.
X1 |
CRYSTAL HC-49/U 4.500MHz |
EYCAP04500 |
Ref#
Description |
MFR.
Part No.
D1 |
DIODE (SMD) 1SS355 |
EDSS00355Y |
D2 |
EDSS00355Y |
D3 |
DIODE (SMD) 1N4148 |
ED1N04148Y |
D4 |
ED1N04148Y |
Ref#
Description |
MFR.
Part No.
Q1 |
T/R (SMD) 2SC2712GR-TE85L |
TY2SC2712G |
Q2 |
TY2SC2712G |
Q3 |
T/R (SMD) 2SC2714Y-TE85L |
TY2SC2714Z |
Q4 |
T/R (SMD) 2SA1162GR-TE85L |
TY2SA1162G |
Ref#
Description |
MFR.
Part No.
L1 |
CHOKE COIL (SMD) 100UH TF J |
YCTLI1073F |
Ref#
Description |
MFR.
Part No.
CN1 |
PCB CONNECTOR/S 7P PH=2MM |
EX07N48224 |
CN2 |
PCB CONNECTOR/S 2P PH=2MM |
EX07N48223 |
CN3 |
PCB CONNECTOR/S 12P PH=2 L=6.8mm |
EX07N48927 |
CN4 |
EX07N48927 |
