Galaxy DX Radios DX2517 (MOSFET Final)
PLL Alignment
See Alignment Location
SETTINGS CONNECTION
ADJUST
ADJUST FOR
REGULATOR VOLTAGE:
RX Mode, AM,
Band D, Ch. 1
Connect Voltmeter positive lead to power switch.
Connect Voltmeter negative lead to PCB ground.
VR601
Adjust for 14.3 VDC
10.240 MHz PLL REFERENCE:
RX Mode, AM,
Band D, Ch. 1
Remove TP7-TP9
Jumper PCB.
Connect Frequency counter
to IC3 Pin 4.
Check for 10.2400MHz ±200 Hz. If tolerance is beyond this, replace X1 (10.240MHz).
VCO OUTPUT:
RX Mode, AM,
Band D, CH. 1
Connect scope to TP3
L15
Adjust for max. RF
VCO VOLTAGE:
RX Mode, AM,
Band D, CH. 1
Connect DC voltmeter to TP2
L14
Adjust for 2.75 VDC ±0.1 Vdc.
Check Band A, CH. 1 for approx. 2.0V. and Band H.
CH. 40 for approx. 6.0V.
PLL MIXER OSCILLATOR:
RX Mode, AM,
Band D, CH. 1
Set Fine and coarse clarifier control to
12 oclock position.
Set clarifier switch
to RX/TX
Connect Frequency Counter to TP3.
L17
AM: Adjust for
16.2700MHz ±20 Hz.
L18
USB: Adjust for
16.2725MHz ±20 Hz.
L19
LSB: Adjust for
16.2675MHz ±20 Hz.
FREQUENCY COUNTER:
Set mode to AM RX
Band D, CH.1
VC1 on Counter PCB
Adjust VC1 on counter PCB for correct reading on display.
Copyright © 2007 CBTricks.com
