Galaxy
DX Radios DX2527
CHASSIS PARTS DX-2527
Ref#
Description |
MFR.
Part No.
POWER SW SDDFA3193A |
EWPS33050X |
C/F/R P-TYPE 47 OHM 1W P |
RCP104704Z |
C/C 0.022UF 50W V SL Z |
CC0502237L |
RF POWER |
C/C 0.001UF 50W V SL Z |
CC0501027L |
LAMP 5V 90mA |
EX01N40080 |
ANT JACK SSB |
EX06N41029 |
ROTARY SW 6N |
EWRT32043S |
V/R 50KA |
RV50303461 |
V/R 50KB/SW |
RV50303462 |
V/R 50KB W/SW |
RV50303518 |
T/F EI-86 110V/220V |
ETP8620129 |
MICROPHONE ASS'Y BLACK DMC512-009 |
EX04N40620 |
E/C 10000UF 35WV Z |
CE0351097Z |
BRIDGE RECTIFIER 10A CM1004 |
EDBGAA121Z |
LEAD WIRE #26 150MM BLACK |
WL0015005Z |
LEAD WIRE #26 150MM RED |
WL0215005Z |
LEAD WIRE #26 80MM BLACK |
WL0008005Z |
SWR PCB MAIN PCB |
LEAD WIRE #26 90MM BLACK |
WL0009005Z |
SWR PCB-MAIN PCB |
LEAD WIRE #26 90MM RED |
WL0209005Z |
SWR PCB-MAIN PCB |
LEAD WIRE #26 90MM BLUE |
WL0609005Z |
TIME TAL VR-ECHO PCB |
LEAD WIRE #26 380MM BLACK |
WL0038005Z |
TIME TAL VR-R237 |
LEAD WIRE #26 480MM GREEN |
WL0548005Z |
WIRE CONNECTOR/H 6-6P |
EX07N48503 |
ECHO/TIME |
WIRE CONNECTOR/H 5P L=360/400MM |
EX07N48873 |
ECHO J7 |
WIRE CONNECTOR/H 2P L=360 PH=2.5MM |
EX07N48872 |
WIRE CONNECTOR/H 2P L=180/160 |
EX07N48506 |
WIRE CONNECTOR/H 4-2-2P |
EX07N48507 |
WIRE CONNECTOR/H 3-2P 2-3P |
EX07N48508 |
WIRE CONNECTOR/H 2P L=200 PH=2.5 |
EX07N48510 |
J108 |
WIRE CONNECTOR/H 2P L=600MM PH=2.5 |
EX07N48874 |
EX07N48512 |
WIRE CONNECTOR/H 3-3P L=320 PH=2.5 |
EX07N48513 |
WIRE CONNECTOR/H 3-3P L=160 |
EX07N48514 |
WIRE CONNECTOR/H 7-7P |
EX07N48515 |
WIRE CONNECTOR/H 2P L=455 PH=2.5 |
EX07N48516 |
WIRE CONNECTOR/H 5-3-3P |
EX07N48517 |
WIRE CONNECTOR/H 6-6P L=100 |
EX07N48518 |
WIRE CONNECTOR/H 3-3P L=230 PH=2.5 |
EX07N48519 |
WIRE CONNECTOR/H 6-3-3P |
EX07N48520 |
WIRE CONNECTOR/H 4-2P |
EX07N48522 |
WIRE CONNECTOR/H 5P-5P-2P |
EX07N48797 |
WIRE CONNECTOR/H 3P L=380MM |
EX07N48798 |
WIRE CONNECTOR/H 4P L=380MM |
EX07N48799 |
EX07N48800 |
LEAD WIRE #18 130MM RED |
WH0213005Z |
LEAD WIRE #18 130MM WHITE |
WH0913005Z |
LEAD WIRE #18 220MM RED |
WH0222005Z |
LEAD WIRE #18 250MM RED |
WH0225005Z |
LEAD WIRE #18 250MM YELLOW |
WH0425005Z |
LEAD WIRE #18 250MM WHITE |
WH0925005Z |
LEAD WIRE #18 510MM RED |
WH0251005Z |
COAXIAL CABLE 200mm 50 OHM |
WX03830200 |
COAX CABLE 1.5D-2VG2.9MM 120MM BLACK |
WX03001012 |
LEAD WIRE #22 190MM ORANGE |
WJ0319005Z |
TIME-6N SW |
SHIELD WIRE #26 150MM GRAY |
WP0815005Z |
MECHANICAL: DX-2527
Ref#
Description |
MFR.
Part No.
RUBBER KEY PANEL |
PTTURB010A |
REFLECTOR PLATE |
PTTURB020A |
DISPLAY WINDOW |
PTTURB030A |
GLASS WINDOW HOLDER |
PT0SSB010A |
PLASTIC FOOT |
PT0SSB040A |
METER BACK COVER |
PT0SSB070A |
ACRY WINDOW |
PT0SSB092A |
KNOB WASHER |
PT3600090A |
MICA INSULATOR TO-3 |
PA0100010A |
REFRACTOR PLATE |
PT2950041A |
HOLDER OF METER |
MTTURB110X |
CHANNEL KNOB |
MTTURB140D |
PUSH BUTTON |
MTTURB150A |
MIC BRACKET |
MT0SSB170N |
INDICTOR NAME PLATE |
MT0SSB101K |
VR KNOB 18Q BLACK |
MT0SSB161B |
TOP COVER BLACK |
MT0SSB010B |
BOTTOM PLATE |
MT0SSB021S |
RIGHT SIDE BRACKET |
MT0SSB071S |
LEFT SIDE BRACKET |
MT0SSB081S |
HANDLE ASSEMBLY BLACK |
MT0SSB120B |
MT0SSB130B |
HANDLE BRACKET |
MT0SSB141S |
HEAT SINK COVER |
MT0SSB310X |
SUPPORTER OF P.T. |
MT0SSB360X |
FIXED PLATE (PT) |
MT0SSB371X |
ECHO PCB |
PCB BRACKET |
MT3001010S |
HEAT SINK C |
MM5500100X |
RUBBER WASHER |
QT0SSB030A |
RUBBER KEY |
QT2950010A |
EARPHONE COVER |
QM5500030A |
TOP COVER |
SHIELD CLOTH A 200x10x0.5t |
LZZZ60018Z |
SPEAKER |
SHIELD CLOTH(C) 106x90x0.5t |
LZZZ60020Z |
FEET |
WASHER(FOR FOOT) 25x9x4t |
LZZZ60021Z |
BOTTOM COVER |
CAUTION LABEL |
LZZZ61066Z |
66,2312x2,473 |
INSULATING RING |
XZZZ90003Z |
8A |
INSULATING PLATE 18x13mm |
XZZZ90020Z |
INSULATING PLATE 10x14x1.55mm |
XZZZ90358Z |
METER |
FOAM 40x8x2 |
XZZZ90061Z |
BUZZER |
SPONGE 22x1.5t |
XZZZ90206Z |
FOAM 10x15x4.5 |
XZZZ90091Z |
2SD797(1),POWER PCB(1),PLATE(1) |
SOLDER PLATE 3.2mm |
XZZZ90002Z |
2SD797 |
INSULATING RING (TO-220D) |
XZZZ90316Z |
WASHER 6x7x10.8t |
XZZZ90057Z |
SWR PCB |
FOAM 14x16x20mm |
XZZZ90004Z |
SPONGE D 30x53x6t |
XZZZ90078Z |
SPONGE RUBBER 108x25x1t |
XZZZ90205Z |
CLAMP |
GZZZ50000Z |
FUSE HOLDER FH-004 |
GZZZ50049Z |
2SD797 |
SET SCREW M3x0.5Px12 |
JS053012MN |
SET SCREW M4x0.7Px12 |
JS114012MQ |
HANDLE |
SET SCREW M5x0.8Px12 |
JS035012MB |
FRONT PLATE |
SET SCREW M3x0.5Px6 |
JS033006MN |
HANDLE(4) TOP COVER(4) |
JS055012MB |
PCB CHASSIS(4) |
SET SCREW M4x0.7Px8 |
JS054008MS |
EARPHONE(2) |
SET SCREW M3x0.5Px8 |
JS053008MB |
C605 |
SET SCREW M3x0.5Px10 |
JS053010MN |
IC(4),473(1) |
SET SCREW M2x0.4Px12 |
JS052012MN |
SET SCREW M3X0.5PX6 W/S/W |
JS013006SN |
HEAT SINK(4) |
SET SCREW M3X0.5PX8 W/S/W |
JS053008SN |
SET SCREW T3x8-2 |
JS053008TB |
HEAT SINK(4) |
SET SCREW W3.2x8-1 |
JS053208WB |
ANT(3) |
SET SCREW T3x8-2 |
JS053008TH |
SPEAKER(4),PLATE(1) |
SET SCREW T3.5x8-2 |
JS053508TH |
FEET(4) |
SET SCREW T3x14-2 |
JS013014TH |
SET SCREW T3x8-2 STEEL |
JS013008TH |
RECIFITER |
SET SCREW M3x0.5Px18 |
JS033018MN |
IC TA7222 |
JS013006MV |
PT |
SET SCREW M4x0.7Px10 |
JS054010MS |
ECHO P.C.B. |
JS053006MN |
2SD797 |
NUT M3x2.4t |
JN243024ZS |
PT |
M4X0.7P LOCK NUT |
JN284007ZN |
EAR PHONE |
INSULATE WASHER 6QX11.5X0.5T |
JW306011EY |
SET (TOP COVER)x4,HANDLE(4) |
WASHER (BLACK) 5.3x12x0.8t |
JW305312FB |
SPRING WASHER 4x6x1t |
JW344006GN |
PCB(5) |
IN-TOOTH WASHER 3Q |
JW323006DN |
NUT WITH WASHER M3x3.5t(m) |
JN263035ZS |
FEET |
WASHER 4Qx9x0.8 |
JW304009FS |
OUT-TOOTH WASHER 5.5x10x0.3tmm |
JW315510CN |
SET SCREW W5x10-1 |
JS015010WH |
FUSE 125V 5A |
EX02N40214 |
MIC STOPPER |
XZZZ90008Z |
REFRACTOR LABEL 28x11 |
LZZZ61278Z |
REFRACTOR LABEL 25x8 |
LZZZ61277Z |
REFRACTOR LABEL 100x10 |
LZZZ61276Z |
