Galaxy DX Radios DX2527
CPU P.C.B. DPT295042Z
Trace Layout
Schematic Diagram
Ref# Description
MFR. Part No.
CPU PCB DPT295042Z
Complete with Components
#T-106R-D10
CPU PCB
DPT295042Z
Resistors
Ref#
Description
MFR. Part No.
CHIP/F/R (SMD) 100 OHM 0.1W
RCY011014Z
R601
CHIP/F/R (SMD) 10K OHM 0.1W
RCY011034Z
R602
CHIP/F/R (SMD) 1M OHM 0.1W
RCY011054Z
R603
RCY011034Z
R604
C/F/R F-TYPE 82 OHM 1/2W
RCU128204Z
R605
CHIP/F/R (SMD) 8.2K OHM 0.1W
RCY018224Z
R606
C/F/R 56 OHM 1/2W U
RCU125604Z
R607
CHIP/F/R (SMD) 4.7K OHM 0.1W
RCY014724Z
R608
CHIP/F/R (SMD) 470K OHM 0.1W
RCY014744Z
R609
CHIP/F/R (SMD) 47K OHM 0.1W
RCY014734Z
R610
RCY011034Z
R611
RCY011034Z
R612
RCY014734Z
R613
RCY014734Z
R614
CHIP/F/R (SMD) 100K OHM 0.1W
RCY011044Z
R615
CHIP/F/R (SMD) 56K OHM 0.1W
RCY015634Z
R616
CHIP/F/R (SMD) 27K OHM 0.1W 5%
RCY012734Z
R617
RCY015634Z
R618
RCY012734Z
R619
RCY015634Z
R620
RCY012734Z
R621
RCY015634Z
R622
RCY015634Z
R623
RCY012734Z
R624
RCY012734Z
R625
RCY015634Z
R626
RCY015634Z
R627
RCY011034Z
R628
RCY014734Z
R629
CHIP/F/R (SMD) 33K OHM 0.1W
RCY013334Z
R630
CHIP/F/R (SMD) 150K OHM 0.1W
RCY011544Z
R631
RCY011034Z
Capacitors
Ref#
Description
MFR. Part No.
C601
CHIP/C (SMD) 33PF 50WV J CH
CK1330AB4A
C602
CHIP/C (SMD) 1UF 16WV Z Y5V
CK5105AB7R
C603
CK5105AB7R
C604
E/C 220UF 10WV Z
CE0102277Z
C605
CHIP/C (SMD) 0.1UF 50WV Z F Y5V
CK1104AB7R
C606
CHIP/C (SMD) 56PF 50WV J CH
CK1560AB4A
C607
CHIP/C (SMD) 0.22UF 50WV Z Y5V
CK1224AB7R
C608
CHIP/C (SMD) 0.001UF 50WV Z SL
CK1102AB7L
C609
CK1102AB7L
C610
CK1104AB7R
C611
CK1104AB7R
C612
CK1104AB7R
C613
CK1104AB7R
C614
CK1104AB7R
C615
CK1104AB7R
C616
CK1104AB7R
C617
CK1104AB7R
Integrated Circuits
Ref#
Description
MFR. Part No.
U601
I.C. (RANGER) HD404818E14FS 80PIN
YNRG2951SP
U602
I.C. (SMD) AN8005M-E2 3PIN
YNMA08005M
U604
I.C. (SMD) BU4094BF 16 PIN
YNRO04094B
U605
YNRO04094B
U606
I.C. (SMD)(EXEL) KXL93LC46P 8PIN
YNEX93L46P
Transistors
Ref#
Description
MFR. Part No.
Q602
T/R (SMD) 2SD999-TP
TY2SD0999Z
Q603
T/R (SMD) 2SC2712GR-TE85L
TY2SC2712G
Q604
T/R (SMD) 2SD999-TP
TY2SD0999Z
Q605
TY2SC2712G
Q606
TY2SC2712G
Q607
TY2SC2712G
Diodes
Ref#
Description
MFR. Part No.
D601
DIODE (SMD) 1SS355
EDSS00355Y
D602
DIODE (SMD) 1SS355
EDSS00355Y
D603
DIODE (SMD) 1SS355
EDSS00355Y
Connectors
Ref#
Description
MFR. Part No.
CN601
PCB CONNECTOR/S 4P T PH=2.5
EX07N41250
CN602
PCB CONNECTOR/S 2P PH=2.5
EX07N41226
CN603
PCB CONNECTOR/S 3P T PH=2.5
EX07N41216
CN604
EX07N41216
CN605
EX07N41216
CN608
EX07N41226
CN610
EX07N41216
SK601
PCB CONNECTOR/S 6P L TYPE
EX07N41280
SK602
PCB CONNECTOR/S 6P T PH=2.5
EX07N41266
JP601/602(J5)
PCB CONNECTOR/S 4P
EX07N48440
SHORT1
PCB CONNECTOR/H SHORT PIN (2P)
EX07N48151
SHORT2(J5)
EX07N48151
Miss.
Ref#
Description
MFR. Part No.
LP601
LAMP 5V 90mA
EX01N40080
LP602
LAMP 5V 90mA
EX01N40080
BZ601
BUZZER PKM17EW-4000
EX14N46511
DISPLAY
LCD DISPLAY MT-628PAT
EX03N40460
X601
CERAMIC RESONATOR 4.0MHz
EX14N46510
Copyright © 2002, 2003, 2004 CBTricks.com
