Galaxy DX Radios DX2527
Power Supply PCB EPTOSSB62A
Schematic Diagram
Ref# Description
MFR. Part No.
Power Supply PCB EPT0SSB62A
Complete with Components
#T-106A-P06
Power Supply PCB
EPT0SSB62A
Resistors
Ref#
Description
MFR. Part No.
R601
C/F/R 1.2K OHM 1W P
RCP101224Z
R602
C/F/R 820 OHM 1W P
RCP108214Z
R603
C/F/R 820 OHM 1W P
RCP108214Z
R604
C/F/R P-TYPE 47 OHM 1W P
RCP104704Z
R605
C/F/R P-TYPE 100 OHM 1W P
RCP101014Z
R606
C/F/R P-TYPE 220 OHM 1W P
RCP102214Z
R607
C/F/R F-TYPE 10K OHM 1/4W U
RCU141034Z
VR601
S/F/R 500 OHM
RE50100063
Capacitors
Ref#
Description
MFR. Part No.
C506
C/C 0.01UF 50WV SL Z
CC0501037L
C507
CC0501037L
C601
CC0501037L
C602
C/C 0.01UF 50WV D M
CC0501036S
C603
C/C 0.047UF 50WV SL Z
CC0504737L
C604
E/C 100UF 35WV Z
CE0351077Z
C606
C/C 0.022UF 100W V Z SL
CC1002237L
Transistors
Ref#
Description
MFR. Part No.
TR601
T/R 2SD471K
T2SD00471K
T/R 2SC5395
T2SC05395Z
TR602
T/R 2SC5395
T2SC05395Z
TR603
T/R 2N6328
  T/R 2N5301
MICA INSULATOR TO-3
PA0100010A
HEAT SINK COVER
MT0SSB310X
HEAT SINK
MM5500100X
Diodes
Ref#
Description
MFR. Part No.
D601
ZENER DIODE 5.6V 1W
EDZD10569Z
D602
ZENER DIODE 16V 1W
EDZD10160Z
Miss.
Ref#
Description
MFR. Part No.
J601
JUMPER WIRE 7x10x7
WX01070710
FUSE BRACKET EC-641
GZZZ50043Z
FUSE 16V 7A
EX02N40210
Copyright © 2002, 2003, 2004 CBTricks.com
