Galaxy DX Radios DX2527
Main PCB (EPT295013Z)
Connectors
Ref#
Bd Loc
Description
MFR. Part No.
J102
PCB CONNECTOR/S 3P T PH=2.5
EX07N41216
J103
PCB CONNECTOR/S 2P PH=2.5
EX07N41226
J104
PCB CONNECTOR/S 5P T PH=2.5
EX07N40038
J105
JUMPER WIRE 7x3MMx7
WX01070703
J107
EX07N41226
J108
EX07N41226
J109
EX07N41216
J110
EX07N41216
J111
PCB CONNECTOR/S 4P T PH=2.5
EX07N41250
J112
EX07N41216
J113
PCB CONNECTOR/S 6P T PH=2.5
EX07N41266
J114
JUMPER WIRE 7x3MMx7
WX01070703
J115
EX07N41216
J116
EX07N41216
J117
PCB CONNECTOR/S 7P T PH=2.5
EX07N41261
J118
EX07N41216
J119
EX07N41266
Jumper Wire
Ref#
Bd Loc
Description
MFR. Part No.
J1
JUMPER WIRE 7x5x7mm
WX01070705
J2
JUMPER WIRE 7x13x7mm
WX01070713
J3
WX01070713
J4
JUMPER WIRE 7x15x7mm
WX01070715
J5
JUMPER WIRE 7x10x7mm
WX01070710
J6
WX01070710
J7
WX01070710
J8
WX01070710
J9
WX01070710
J10
WX01070710
J11
JUMPER WIRE 7x6x7mm
WX01070706
J12
TUMPER WIRE 7X9X7mm
WX01070709
J13
JUMPER WIRE 7x5x7mm
WX01070705
J14
JUMPER WIRE 7x7x7mm
WX01070707
J16
JUMPER WIRE 7x5x7mm
WX01070705
J17
WX01070710
J18
WX01070713
J19
JUMPER WIRE 7x4x7mm
WX01070704
J20
JUMPER WIRE 7x6x7mm
WX01070706
J21
WX01070710
J22
JUMPER WIRE 7x6x7mm
WX01070706
J23
JUMPER WIRE 7x6x7mm
WX01070706
J24
JUMPER WIRE 7x6x7mm
WX01070706
J25
JUMPER WIRE 7x6x7mm
WX01070706
J26
JUMPER WIRE 7x6x7mm
WX01070706
J27
WX01070710
J28
TUMPER WIRE 7X9X7mm
WX01070709
J29
JUMPER WIRE 7x4x7mm
WX01070704
J30
JUMPER WIRE 7x5x7mm
WX01070705
J31
JUMPER WIRE 7x7x7mm
WX01070707
J32
JUMPER WIRE 7x6x7mm
WX01070706
J33
WX01070710
J34
WX01070710
J34
WX01070715
J36
TUMPER WIRE 7X9X7mm
WX01070709
J38
JUMPER WIRE 7x3x7mm
WX01070703
J39
JUMPER WIRE 7x27x7mm
WX01070727
J40
WX01070710
J41
JUMPER WIRE 7x5x7mm
WX01070705
J42
WX01070710
J43
TUMPER WIRE 7X9X7mm
WX01070709
J44
WX01070710
J45
WX01070710
J46
WX01070713
J47
JUMPER WIRE 7x5x7mm
WX01070705
J48
JUMPER WIRE 7x5x7mm
WX01070705
J49
WX01070710
J50
WX01070710
J51
WX01070710
J53
JUMPER WIRE 7x5x7mm
WX01070705
J54
JUMPER WIRE 7x6x7mm
WX01070706
J55
JUMPER WIRE 7x5x7mm
WX01070705
J57
JUMPER WIRE 7x4x7mm
WX01070704
J58
WX01070710
J59
JUMPER WIRE 7x5x7mm
WX01070705
J60
JUMPER WIRE 7x6x7mm
WX01070706
J61
JUMPER WIRE 7x6x7mm
WX01070706
J62
JUMPER WIRE 7x4x7mm
WX01070704
J63
JUMPER WIRE 7x8x7mm
WX01070708
J64
WX01070710
J66
WX01070710
J67
JUMPER WIRE 7x14x7mm
WX01070714
J68
JUMPER WIRE 7x6x7mm
WX01070706
J69
WX01070710
J70
JUMPER WIRE 7x5x7mm
WX01070705
J71
JUMPER WIRE 7x4x7mm
WX01070704
J72
JUMPER WIRE 7x5x7mm
WX01070705
J73
JUMPER WIRE 7x5x7mm
WX01070705
J74
WX01070710
J75
JUMPER WIRE 7x8x7mm
WX01070708
J76
JUMPER WIRE 7x7x7mm
WX01070707
J78
JUMPER WIRE 7x7x7mm
WX01070707
J79
JUMPER WIRE 7x6x7mm
WX01070706
J80
JUMPER WIRE 7x6x7mm
WX01070706
J81
WX01070713
J82
WX01070715
J83
JUMPER WIRE 7x7x7mm
WX01070707
J84
WX01070714
J86
JUMPER WIRE 7x5x7mm
WX01070705
J101
JUMPER WIRE 7x3x7mm
WX01070703
C322
JUMPER WIRE 7x5x7mm
WX01070705
C315
JUMPER WIRE 7x5x7mm
WX01070705
ANT
JUMPER WIRE 7x50x7mm
WX01070750
Copyright © 2002 CBTricks.com
