Galaxy DX Radios DX2527
PLL Alignment
PLL Alignment Locations
SETTINGS CONNECTION
ADJUST
ADJUST FOR
VOLTAGE REGULATOR:
(EPTOSSB62A)
Connect Voltmeter positive lead to power switch. Connect Voltmeter negitive lead to PCB ground.
VR601
Adjust for 13.8VDC
VCO & OSC:
Frequency: 28.0000 MHz
MIC Gain: Fully counter-clockwise
RF Power. Fully clockwise
RF Gain: Fully clockwise
Clarifier: 12 o'clock
Vol : Comfortable level
Squelch: Fully counter-clockwise
Mode selector - AM
Disconnect shorting board from test points TP1, TP2 and TP3
Connect Freq. Counter to L61
VC1
Adjust for reading of
10.240MHz ±10 Hz.
Connect Oscilloscope to L61
L4
Adjust for Max.
Connect a Freq. Counter to L65
VC2
Adjust for 17.305MHz ±10 Hz.
VR21
Key Transmitter and adjust for
17.305MHz ±10 Hz.
Connect Voltmeter to IC7 Pin3
L21
Adjust for
1.2VDC±0.1 VDC
Connect Voltmeter to J13
L17
Adjust for
2.0VDC±0.1 VDC
Connect Oscilloscope to L65
L19
Adjust for Max.
IC13 pin8
L23
Very carefully adjust for
11.350MHz ±10 Hz.
IC17 pin13
L24
L25
Very carefully adjust and for best waveform
AM TX OSC:
Same as above
Connect a frequency counter to cathode of D45
L27
Key transmitter and adjust for
10.6950 MHz ±10 Hz.
USB TX OSC:
Adjust VR7 fully clockwise.
Put mode selector on USB.
Leave frequency counter connected to D45
L29
10.6925 MHz ±10 Hz.
LSB TX OSC:
Put mode selector in LSB.
After adjustment return VR7 to approximate middle of rotation
Replace shorting board to test points TP1, TP2 and TP3
L28
10.6975 MHz ±10 Hz.
Copyright © 1998,1999,2000, 2002 CBTricks.com
