Galaxy DX Radios DX2527
TX Alignment
TX Alignment Locations
SETTINGS CONNECTION
ADJUST
ADJUST FOR
DRIVER BIAS:
Set mode to LSB
Mic Gain to minimum
Connect DC Ammeter between TP1 and TP3.
VR11
In TX adjust for 50-75mA.
FINAL BIAS:
Set mode to LSB
Mic Gain to minimum
Connect DC Ammeter between TP2 and TP3.
N/A
 In TX check for 160-180mA.
Mode LSB
Frequency to 28.000MHz
Adjust VR14
fully counterclockwise.
Adjust VR12
Set generator for 30mV RMS, 1KHz sinewave.
Connect an audio generator to (pin 2) and ground (pin 1) of Mic connector.
Connect a wattmeter and 50ohm dummy load to the antenna connector. Set wattmeter for 30W scale.
Mic Gain
Key the transmitter and slowly increase Mic Gain until you obtain about 10W.
L19, L48
L47, L46,
L43, VC3
Adjust for maximum reading on wattmeter. Reduce RF gain if necessary to maintain about 10 to 15W on wattmeter.
Increase Mic gain to maximum
(fully clockwise).
Same as above.
L34
Adjust for maximum output power
SSB CARRIER BALANCE:
Set mode to USB
MIKE GAIN to minimum.
Same as above.
VR7
Key TX; adjust for minimum carrier on scope or wattmeter. If necessary readjust for best balance of sideband suppression between LSB & USB
SSB HIGH PWR:
With Mic gain still a maximum on LSB
Set RF PWR control on radio to minimum.
Same as above.
VR12
Key the transmitter and adjust for 28W.
SSB LOW PWR:
Same as above.
VR16
 Key the transmitter and adjust for 10W.
AM POWER HIGH:
Set RF PWR control on radio to maximum
Put mode selector on AM.
Mic Gain to minimum
VR13
Key transmitter with no modulation applied and adjust for 10W.
AM POWER LOW:
Mic Gain to minimum
VR15
 Key transmitter with no modulation applied and adjust for 2W.
RF METER:
Set RF PWR control on radio to maximum.
Mic Gain to minimum.
VR8
Adjust so panel meter agrees with Wattmeter.
AMC:
Mode to AM
With Mic gain at maximum
Same as above.
VR14
Adjust for 100% modulation. Use modulation meter or oscilloscope with RF sampler.
FM DEVIATION:
Put mode selector on FM
Key transmitter and check for 4kHz deviation � 0.5 kHz. Use deviation meter or service monitor.
N/A
Simply check for sufficient transmit audio.
There is no deviation adjustment provided in this radio.
Copyright © 1998,1999,2000, 2002 CBTricks.com
