Galaxy
DX Radios DX2547
Clarifier Mod Method 1
Also SEE:
Method
#2
Method 1: |
1.
First, remove power to the radio. Remove the bottom chassis cover of the radio. |
2.
Remove R113 and D68 as shown above. |
3.
Connect a jumper wire between +8V and J9 pin F1. |
4.
Perform an PLL alignment as shown below. |
AM Frequency: Set radio to CH 1 AM RX mode. Clarifier control to center detent. |
Connect frequency counter to TP3. |
L20
16.27000 MHz � 20 Hz |
USB
Freq: Set radio to CH 1 USB mode. Clarifier control to center detent. |
L21 |
16.27250 MHz � 20 Hz |
LSB Freq: Set radio to CH 1 LSB mode. Clarifier control to center detent. |
L22
16.26750 MHz � 20 Hz |
