Galaxy DX Radios DX2547
ANF/GNF P.C.B. (EPT009830Z)
Trace Layout
Schematic Diagram
Ref#
Description
MFR. Part No.
ANF P.C.B. EPT009830Z Complete with Components
#H-590-P03
ANF P.C.B. ALSN-98
EPT009830Z
Resistors
Ref#
Description
MFR. Part No.
R301
CHIP/F/R (SMD) 47K OHM 0.1W
RCY014734Z
R302
RCY014734Z
R303
CHIP/F/R (SMD) 100K OHM 0.1W
RCY011044Z
R304
RCY011044Z
R305
CHIP/F/R (SMD) 15K OHM 0.1W 5%
RCY011534Z
R306
RCY011044Z
R307
RCY011534Z
R308
CHIP/F/R (SMD) 100 OHM 0.1W
RCY011014Z
R309
CHIP/F/R (SMD) 10K OHM 0.1W
RCY011034Z
R310
RCY011034Z
R311
RCY011034Z
R312
CHIP/F/R (SMD) 10 OHM 0.1W
RCY011004Z
R313
RCY011034Z
R314
RCY011034Z
R315
RCY011034Z
R316
CHIP/F/R (SMD) 270 OHM 0.1W
RCY012714Z
R317
RCY011534Z
R318
RCY011034Z
R319
RCY011034Z
R320
RCY011034Z
R321
RCY011034Z
R322
RCY011044Z
R323
CHIP/F/R (SMD) 2.2K OHM 0.1W
RCY012224Z
R324
CHIP/F/R (SMD) 4.7K OHM 0.1W
RCY014724Z
R325
CHIP/F/R (SMD) 1K OHM 0.1W
RCY011024Z
R326
RCY011034Z
R327
RCY014734Z
Capacitors
Ref#
Description
MFR. Part No.
C301
CHIP/C (SMD) 560PF 50WV K SL
CK1561AB5L
C302
CHIP/C (SMD) 100PF 50WV K SL
CK1101AB5L
C303
CHIP/C (SMD) 0.022UF 50WV Z Y5V
CK1223AB7R
C304
CHIP/C (SMD) 0.1UF 25WV Z Y5V
CK2104AB7R
C305
CHIP/C (SMD) .0047UF 50WV K X7RP
CK1472AB5X
C306
CK1472AB5X
C307
CK1561AB5L
C309
CHIP/C (SMD) 0.01UF 50WV M Z5U K X7R
CK1103AB6U
C310
T/C (SMD) 4.7UF 16WV M ('A'CASE)
CTY164756Z
C311
CK1103AB6U
C312
CHIP/C (SMD) 0.047UF 50WV Z Y5V
CK1473AB7R
C313
CHIP/C 0.0033 UF 50WV Z Y5 (K X7R)
CK1332AB7R
C314
CK1473AB7R
C315
CHIP/C (SMD) 0.033UF 50WV M Z5U K X7R
CK1333AB6U
C316
CK2104AB7R
C317
CK1103AB6U
C319
CK2104AB7R
C320
CK2104AB7R
C321
CK1103AB6U
C322
CK1103AB6U
Integrated Circuits
Ref#
Description
MFR. Part No.
IC301
I.C.(JRC) (SMD) NJM324M 14PIN
YNJR00324M
Transistors
Ref#
Description
MFR. Part No.
Q301
T/R (SMD) 2SC2712GR-TE85L
TY2SC2712G
Q302
T/R (SMD) RN1403 -TE85L
TYZRN1403Z
Diodes
Ref#
Description
MFR. Part No.
D301
DIODE (SMD) 1SS226 -TE85L
EDSS00226Y
Hardware
Ref#
Description
MFR. Part No.
IC PIN 022-1.0-S(WAKO)
GZZZ50098Z
Copyright © 1998,1999,2000,2002 CBTricks.com
