Galaxy DX Radios DX2547
Frequency Counter PCB (EPT900040Z)
Trace Layout
Ref#
Description
MFR. Part No.
FC-97 (DX-2547) COUNTER EPT900042Z
#T-148A-P12
COUNTER P.C.B. 62x34.5x1.6tmm (d)
EPT900042Z
Resistors
Ref#
Description
MFR. Part No.
R3
CHIP/F/R (SMD) 10K OHM 0.1W
RCY011034Z
R4
CHIP/F/R (SMD) 2.2K OHM 0.1W
RCY012224Z
R5
RCY012224Z
R6
CHIP/F/R (SMD) 680 OHM 0.1W
RCY016814Z
R7
CHIP/F/R (SMD) 1K OHM 0.1W
RCY011024Z
R9
CHIP/F/R (SMD) 470 OHM 0.1W
RCY014714Z
R10
RCY011034Z
R11
CHIP/F/R (SMD) 33K OHM 0.1W
RCY013334Z
R12
RCY011034Z
R13
CHIP/F/R (SMD) 22K OHM 0.1W
RCY012234Z
R14
RCY012234Z
R15
RCY012234Z
R16
RCY012234Z
R17
RCY012234Z
R18
RCY012234Z
R19
RCY016814Z
R20
RCY016814Z
R21
RCY016814Z
R22
RCY016814Z
R23
RCY016814Z
R24
RCY016814Z
R25
RCY016814Z
R26
RCY016814Z
R27
RCY016814Z
R28
RCY016814Z
R29
RCY016814Z
R30
RCY016814Z
R31
RCY016814Z
R32
RCY016814Z
R33
RCY016814Z
R34
RCY016814Z
R35
RCY016814Z
R36
RCY016814Z
R37
RCY016814Z
R38
RCY016814Z
R39
RCY016814Z
R40
CHIP/F/R (SMD) 0 OHM 0.1W
RCY010004Z
R41
CHIP/F/R (SMD) 47K OHM 0.1W
RCY014734Z
R42
RCY014734Z
Variable Capacitors
Ref#
Description
MFR. Part No.
VC1
TRIMMER/C(SMD) 20PF TCZ03P200A110B00
CV038200AY
Capacitors
Ref#
Description
MFR. Part No.
C1
E/C 100UF 16WV H=5mm
CEM161077A
C2
CHIP/C (SMD) 0.1UF 25WV Z Y5V
CK2104AB7R
C3
CEM161077A
C5
CHIP/C (SMD) 0.01UF 50WV M Z5U K X7R
CK1103AB6U
C6
CK2104AB7R
C7
CK1103AB6U
C8
CK2104AB7R
C9
CHIP/C (SMD) 1UF 16WV Z Y5V
CK5105AA7R
C10
CK2104AB7R
C11
CK2104AB7R
C12
CK2104AB7R
C13
CHIP/C (SMD) 0.001UF 50WV Z SL (K X7R)
CK1102AB7L
C14
CHIP/C (SMD) 33PF 50WV J CH
CK1330AB4A
C15
CHIP/C (SMD) 15PF 50WV J CH
CK1150AB4A
C16
CK1103AB6U
C17
CK2104AB7R
C18
CK5105AA7R
C19
CK2104AB7R
C20
CK1103AB6U
C21
CK2104AB7R
C22
CK1103AB6U
C25
CK1103AB6U
C27
CK5105AA7R
C28
CK2104AB7R
C29
CK2104AB7R
C30
CK5105AA7R
C31
CK2104AB7R
C32
CK2104AB7R
C33
CK2104AB7R
C34
CK5105AA7R
C35
CK2104AB7R
C36
CK2104AB7R
C37
E/C 1000UF 16WV Z
CE0161087Z
C38
CK1103AB6U
C40
CK1103AB6U
Integrated Circuits
Ref#
Description
MFR. Part No.
U1
I.C.(MATSU)(SMD) AN8005M-E2 3PIN
YNMA08005M
U2
I.C. (SMD) TC4093BFN 14PIN
YNTA0403B
U3
I.C. 80PIN LC7232N-8985
YNRG0GX3SP
U4
IC (SMD) BA6250F-TP 16PIN
YNRO06250F
U5
YNRO06250F
U6
YNRO06250F
Transistors
Ref#
Description
MFR. Part No.
Q1
T/R (SMD) 2SC2712GR-TE85L
TY2SC2712G
Q2
TY2SC2712G
Q3
TR (SMD) 2SC2714 -TE85L
TY2SC2714Z
Diodes
Ref#
Description
MFR. Part No.
D2
DIODE (SMD) 1SS355
EDSS00355Y
D3
DIODE (SMD) 1SS355
EDSS00355Y
D4(R6)
DIODE (SMD) 1SS355
EDSS00355Y
Inductors
Ref#
Description
MFR. Part No.
L1
CHOKE COIL(SMD) NL453232T-102J
YCTLI1083F
Crystals
Ref#
Description
MFR. Part No.
X1
CRYSTAL HC-49/U 4.500MHz
EYCAP04500
Connectors
Ref#
Description
MFR. Part No.
CN1
PCB CONNECTOR/S 2P PH=2MM
EX07N48223
CN2
PCB CONNECTOR/S 7P PH=2MM
EX07N48224
PCB CONNECTOR/S 12P PH=2 L=6.8mm
EX07N48927
Copyright © 2003 CBTricks.com
