Galaxy DX Radios DX2547
PLL Alignment
See Alignment Locations
SETTINGS CONNECTION
ADJUST
ADJUST FOR
Power Supply:
Connect Voltmeter positive lead to power switch.
Connect Voltmeter negative lead to PCB ground.
VR701 Adjust for 13.8 VDC
VCO:
Disconnect the "short PCB" from TP7, TP8 and TP9.
Set radio to CH 20 AM RX mode. Clarifier setting in 12 o'clock.
Connect FC to IC3 Pin 8
Connect DVM to TP2.
Connect Oscope to TP3
VC1
L14
L15
Adjust for 10.24000MHz ±20Hz.
Adjust for 3.0 VDC ±0.1
Adjust for max.
AM Frequency:
Connect frequency counter to TP3.
L20
16.51000 MHz ±20Hz.
USB Freq:
Set radio to CH 20 USB mode.
L21
16.51250 MHz ±20Hz.
LSB Freq:
Set radio to CH 20 LSB mode.
L22
16.50750 MHz ±20Hz.
FREQUENCY COUNTER:
Set mode to AM RX
CH. 20
VC1 on Counter PCB
Adjust VC1 on counter PCB for correct reading on display.
Copyright © 1998,1999,2000, 2001 CBTricks.com
