Galaxy DX Radios DX2547
Receiver Alignment
See Alignment Locations
SETTINGS CONNECTION
ADJUST
ADJUST FOR
AM Sensitivity:
Set radio to CH 19 AM RX MODE.Clarifier setting at 12 o'clock.RF Gain fully clockwise, SQ fully counter clockwise. VOL control at 2 o'clock. Output Frequency 27.185 MHz, MOD 30%.
Connect AF VTVM or scope across speaker terminals.
Connect RF SG to antenna jack
(in order)
L2, L3, L5, L6, L7, L8, L9, L10
L6, L7
Audio output > 2V@10dB S/N. Balance between CH 1 and CH 40
USB Sensitivity:
Set radio to CH 19 USB mode.VOL control fully clockwise.RF SG setting to 27.186 MHz @ 0.5 uVMOD to off
Same as above
L11, L12
Audio output > 2VS/N 10 dB
LSB Sensitivity:
Set radio to CH 19 LSB mode.VOL control fully clockwise.RF SG setting to 27.184 MHz @ 0.5 uVMOD to off
Connect AF VTVM or scope to IC2 Pin 7.
RF Generator to ANT Jack
L11, L12
Adjust for maximum audio output.
NB Adjust:
Set radio to CH 20 AM mode
RF SG setting 27.215 MHz @ 1000uV
MOD 30%, NB/ANL switch on.
Connect Voltmeter to TP1
L1
DC voltage to max.(>2.0V)
AM Squelch:
Set radio to CH 19 AM mode
SQ control fully clockwise.
RF SG setting 10 mV, MOD 30%
VR4
Adjust very slowly until squelch just closes
SSB Squelch:
Set radio to CH 19 USB mode.SQ control fully clockwise.RF SG setting 10 mV
VR3
AM S-Meter:
Set radio to CH 19 AM mode. Meter switch at S/RF position. RF SG setting to 27.185 MHz @ 100 uVMOD 30%,
VR1
Adjust needle on S-Meter to "9" on the S scale
SSB S-Meter:
Set radio to CH 19 USB mode.S/RF switch at S/RF position.RF SG setting 27.186 Mhz, MOD off 100 uV
VR2
Copyright © 1998,1999,2000, 2001 CBTricks.com
