Galaxy
DX Radios DX2547
CHASSIS AND MECHANICAL PARTS DX-2547
Ref#
Description |
MFR.
Part No.
DC JACK |
C/C 0.01UF 50WV SL Z |
CC0501037L |
C/F/R P-TYPE 47 OHM 1W P |
RCP104704Z |
DC JACK |
C/F/R P-TYPE 2.2M OHM 1W P |
RCP102254Z |
DC JACK |
HV DISC/C .001UF DD0505E102Z1KMSS1 |
CX0071027Z |
SPEAKER 8ohm 3W 3.5in |
ES300835SQ |
METER |
PILOT LAMP 10V W/UL L=200mm |
EX01N40056 |
FUSE HOLDER |
FUSE 125V 5A |
EX02N40214 |
SIGNAL METER TN-65D-9129 |
EX03N40489 |
FUSE HOLDER FH-004 |
GZZZ50049Z |
POWER SW SDDFA3193A |
EWPS33050X |
SLIDE SW 2C2T L=5 |
EWSL31060K |
AC JACK S3-750T-101 |
EX06N41220 |
DC JACK 3P |
EX06T40007 |
ANT JACK |
EX06N41029 |
PHONE JACK 6.3 |
EX06N41221 |
DIODE LT6A400 |
EDLT6A400Z |
DC/AC-DC I/P |
CHOKE COIL 0.47UH |
ECCHK16000 |
Ref#
Description |
MFR.
Part No.
FRONT PANEL |
PT2537010A |
DX-2547 |
DISPLAY WINDOW |
PT2537020C |
CHANNEL KNOB |
PT2537030A |
VR KNOB |
PT2537040A |
INNER KNOB |
PT2537050A |
OUTER KNOB |
PT2537060A |
POWER |
PUSH BUTTON |
PT2537070A |
ANL |
PUSH BUTTON(4) |
PT2537080D |
NB |
PUSH BUTTONN(4) |
PT2537080E |
GNF |
PUSH BUTTON(4) |
PT2537080F |
CLARIFIER |
PUSH BUTTON(4 |
PT2537080G |
RB PA |
PUSH BUTTON(2) |
PT2537090A |
RED |
MASK WINDOW(B) DX-2547 |
PT2537130A |
KNOB |
KNOB WASHER |
PT3600090A |
DISPLAY BAR DX-2547 |
PTDX55050A |
METER BACK COVER |
PT0SSB070A |
MICA INSULATOR TO-3 |
PA0100010A |
MODE PLATE |
BT2537050A |
TOP HOUSING |
MT2537010B |
BOTTOM HOUSING |
MT2537020B |
FRONT CHASSIS |
MT2537030X |
MAIN CHASSIS |
MT2537040X |
SIDE PLATE |
MT2537060X |
REAR PANEL(B) |
MT2537070A |
MAIN PCB |
SET W/NUT CHASSIS |
MT3001021X |
BRAND PLATE VX-3000 |
BTRSB3030B |
DISPLAY-CONNTER PCB |
HEX SPACER (CBS-5A) |
GZZZ50182Z |
REAR PANEL |
EARPHONE COVER |
QM5500030A |
LAMP STOPPER |
QT0SSB020A |
SPEAKER |
SHIELD CLOTH 90x55x0.5t |
LZZZ60078Z |
TOP & BOTTOM HOUSING |
SHIELD CLOTH 160x10x0.5t |
LZZZ60079A |
TOP HOUSING |
SHIELD CLOTH 220x45x0.5t |
LZZZ60080Z |
BOTTOM HOUSING&REAR PANE |
SHIELD CLOTH 170x45x0.5t |
LZZZ60081Z |
METER |
FOAM 14x14x2 |
XZZZ90053Z |
ANT |
SOLDER PLATE 3.2mm |
XZZZ90002Z |
COUNTER PCB |
SPONGE 22x15x4tmm |
XZZZ90367A |
SP(4) |
NUT WITH WASHER M3x3.5t |
JN263035ZS |
PT(4) |
M4X0.7P LOCK NUT |
JN284007ZN |
5301Z(2) |
NUT M3x2.4t |
JN243024ZS |
20Z PCB(2) |
NUT M3x2.4t |
JN243024ZS |
40Z PCB(2) |
NUT M3x2.4t |
JN243024ZS |
SET SCREW M3x0.5Px18 |
JS033018MN |
PT(4) |
ROUND HEAD M4x0.7Px16 |
JS014016MS |
FRONT PANEL(4) |
SET SCREW T3x8-2 STEEL |
JS013008TH |
FRONT PANEL(4) |
SET SCREW M3x0.5Px6 |
JS033006MN |
MAIN PCB(4) |
SET SCREW M3x0.5Px8 |
JS033008MN |
AC/DC |
SET SCREW M2x0.4Px4 |
JS052004MN |
SWITCH |
JS052004MN |
SET CHASSIS(6) |
JS053006MN |
MAIN PCB(5) |
SET SCREW T3x6-2mm |
JS053006TN |
40Z PCB(1) |
JS053006TN |
ANT JACK(1) |
JS053008MN |
ANT JACK(3) |
JS053006TN |
ANT(1) |
JN263035ZS |
AC JACK(2) |
JS053008MN |
DC JACK(2) |
JS053008MN |
SW 50X(2) |
SET SCREW M3X0.5PX6 |
JS013006SN |
MAIN CHASSIS(4� W/S/W 6 ) |
JS013006SN |
TOP HOUSING(8) |
SET SCREW M3x0.5Px6 BLACK |
JS053006MB |
HOUSING(8) |
JS053006MB |
SP(4) |
JS053008MB |
AC CORD 175cm (UL) 3P |
WA0100175A |
DC CORD W/FUSE SOCKET |
WA0012185A |
FEET (A) DX-2547 |
PT2537180A |
FEET (B) DX-2547 |
PT2537190A |
FEET (C) DX-2547 |
PT2537200A |
FUSE 125V 5A |
EX02N40214 |
MIC (RANGER)(4P) SRA-112 (#R-114) |
EX04N40704 |
MIC PLATE GALAXY |
BA0112010A |
JS053006MB |
SET SCREW W5x10-1 |
JS015010WH |
JS013008TH |
OUT-TOOTH WASHER 5.5x10x0.3tmm |
JW315510CN |
IN-TOOTH WASHER 4x8x0.3tmm |
JW324008CN |
MIC STOPPER PCS |
XZZZ90008Z |
I/M DX-2547 |
AT2547011A |
