Galaxy DX Radios DX33HML
Echo PCB (EPT0SSB51J) Board Layout
Trace Layout
Schematic Diagram
Schematic Diagram
Ref#
Description
MFR. Part No.
EB-2000B EPT0SSB51J Complete with Components
#T-140H-P13
EB-2000B P.C.B. 62x46x1.6tmm(d)
EPT0SSB51J
Resistors
Ref#
Description
MFR. Part No.
R1
CHIP/F/R (SMD) 22K OHM 0.1W
RCY012234Z
R2
RCY012234Z
R3
CHIP/F/R (SMD) 100 OHM 0.1W
RCY011014Z
R4
CHIP/F/R (SMD) 47K OHM 0.1W
RCY014734Z
R5
RCY012234Z
R6
CHIP/F/R (SMD) 33K OHM 0.1W
RCY013334Z
R7
CHIP/F/R (SMD) 2.2K OHM 0.1W
RCY012224Z
R13
RCY013334Z
R14
CHIP/F/R (SMD) 27K OHM 0.1W 5%
RCY012734Z
R15
RCY013334Z
R16
CHIP/F/R (SMD) 1.5K OHM 0.1W
RCY011524Z
R17
CHIP/F/R (SMD) 1K OHM 0.1W
RCY011024Z
R18
RCY012734Z
R20
RCY014734Z
R21
CHIP/F/R (SMD) 100K OHM 0.1W
RCY011044Z
R22
CHIP/F/R (SMD) 10K OHM 0.1W
RCY011034Z
R23
RCY011034Z
R24
RCY011034Z
R26
RCY012224Z
R27
RCY011024Z
R28
RCY012234Z
R29
CHIP/F/R (SMD) 4.7K OHM 0.1W
RCY014724Z
R30
RCY014724Z
R31
RCY011044Z
R32
RCY011034Z
R33
RCY014734Z
R34
RCY014734Z
Capacitors
Ref#
Description
MFR. Part No.
C1
CHIP/C (SMD) 4.7UF 16WV� Z� Y5V
CK5475AA7R
C2
CHIP/C (SMD) 0.1UF 25WV Z Y5V
CK2104AB7R
C3
CK2104AB7R
C4
CHIP/C (SMD) 0.01UF 25WV Z Y5V
CK2103AB7R
C5
CHIP/C (SMD) 560PF 50WV K CH
CK1561AB5A
C6
CHIP/C (SMD) 1UF 16WV Z Y5V
CK5105AB7R
C10
CK2104AB7R
C11
CK2103AB7R
C12
CHIP/C (SMD) 0.001UF 50WV Z SL
CK1102AB7L
C13
CK1561AB5A
C14
CHIP/C (SMD) 0.0022UF 50WV Y5V
CK1222AB7R
C16
CHIP/C (SMD) 0.047UF 50WV Z Y5V
CK1473AB7R
C18
CK1473AB7R
C19
CK2103AB7R
C20
CK5105AB7R
C22
CHIP/C (SMD) 2.2UF 16WV Z Y5V
CK5225AB7R
C23
CK2103AB7R
C25
CK5105AB7R
C26
CHIP/C (SMD) 470PF 50WV K CH
CK1471AB5A
C27
E/C 47UF 16WV Z
CE0164767Z
C28
CHIP/C (SMD) 0.15UF 50WV Z Y5V
CK1154AB7R
C29
CK1154AB7R
C30
CK2104AB7R
C31
CK5475AA7R
C32
CK2104AB7R
C33
CK2104AB7R
C34
CK2103AB7R
C35
CHIP/C (SMD) 0.022UF 50WV M Z5U
CK1223AB6U
C36
CK2104AB7R
C37
CK2104AB7R
C38
CK2104AB7R
C39
CK2104AB7R
C40
CK2104AB7R
C41
CK5105AB7R
C42
CK2104AB7R
C43
E/C 100UF 16WV Z
CE0161077Z
Integrated Circuits
Ref#
Description
MFR. Part No.
IC1
I.C. (SMD) NJM4558M 8PIN
YNJR04558M
IC2
I.C. (SMD) ES56033S 16PIN
YNES56033S
Transistors
Ref#
Description
MFR. Part No.
Q1
T/R (SMD) 2SC2712GR-TE85L
TY2SC2712G
Q2
T/R (SMD) RN1403 -TE85L
TYZRN1403Z
Q3
TY2SC2712G
Q4
F.E.T. (SMD) 2SK208
FY2SK0208Z
Q5
TYZRN1403Z
Q6
TYZRN1403Z
Diodes
Ref#
Description
MFR. Part No.
D1
DIODE (SMD) 1SS355
EDSS00355Y
D3
ZENER DIODE (SMD) RLZ 5.6V
EDZD05569Y
D4
DIODE (SMD) 1SS355
EDSS00355Y
D5
DIODE (SMD) 1SS355
EDSS00355Y
D6
DIODE (SMD) 1SS355
EDSS00355Y
Connectors
Ref#
Description
MFR. Part No.
J1
PCB CONNECTOR/S 2P PH=2MM
EX07N48223
J1
WIRE CONNECTOR/H 2P L=180MM PH=2MM
EX07N48888
J2
PCB CONNECTOR/S 3P T PH=2.5(WHITE)
EX07N41227
J3
EX07N41216
J3
WIRE CONNECTOR/H 3P-3P L=130MM
EX07N48902
J4
PCB CONNECTOR/S 3P PH=2MM
EX07N48350
J4
WIRE CONNECTOR/H 3P L=240mm PH=2mm
EX07N49013
J5
PCB CONNECTOR/S 6P PH=2
EX07N48331
J5
WIRE CONNECTOR/H 6P L=280MM PH=2
EX07N49116
Hardware
Ref#
Description
MFR. Part No.
ECHO COVER
MT2100061X
ECHO BOX
MT2100070X
BRACKET OF ECHO BOX
MT2100081X
SET SCREW M3x0.5Px6
JS053006MN
FIBER BOARD
XZZZ90376Z
SET SCREW M3x0.5x4
JS013004MY
Copyright © 1998,1999,2000, 2001, 2002, 2003 CBTricks.com
