Galaxy DX Radios DX33HML
Chassis Parts
Ref#
Description
MFR. Part No.
DC SKT(2)
DC JACK 3P
EX06T40007
DC SOCKET HOLDER
MT3600050X
DC(2)
SET SCREW M3x0.5Px8
JS053008MN
DC SKT(2)
C/C 0.01UF 50WV SL Z
CC0501037L
DIODE LT6A400
EDLT6A400Z
ANT JACK
EX06T41019
ANT JACK
JUMPER WIRE 7x50mmx7
WX01070750
SET CHASSIS
MT3001024M
VOI-S0
V/R 50KB/50KA/SW
RV50303344
MI GAIN-RF GAIN
V/R 1KB/1KA
RV10203345
ECHO
V/R 50KB
RV50303378
TIME
V/R 50KB
RV50303378
BAND (FM/AM/PA)
ROTARY SW 3N
EWRT32001S
KNOB WASHER
PT3600090A
SINGLE
KNOB C-1
PT3600120A
CH
KNOB (A-1)
PT3600101A
INNER
KNOB B-1(CHROM)
PT3600110A
OUTER
KNOB D-1(CHROM)
PT3600130A
D SPRING A #6600
MT3600080T
D SPRING B #7800
MT3600090T
D SPRING D #8500
MT3600100T
SLIDE SW 3N
EWSL31000S
SLIDE SW 2N
EWSL31001S
Tone(2)
SET SCREW M2x0.4Px4
JS052004MN
CH9(2)
SET SCREW M2x0.4Px4
JS052004MN
WB/An1 SW(2)
SET SCREW M2x0.4Px4
JS052004MN
SPEAKER 8 ohm� 3W 3.5in
ES300835SQ
Speaker(4)
SET SCREW M3x0.5Px8
JS053008MN
SIGNAL METER L=250mm
EX03N40407
METER HOLDER
PT3600080A
PLL CORD
WIRE CONNECTOR/H 10P 125mm
EX07N40013
J106
WIRE CONNECTOR/H 2P L=180MM
EX07N48041
J109
EX07N48041
J101
WIRE CONNECTOR/H 4P 160MM
EX07N41355
J104
EX07N41355
EB-99(J2)(MIO-12)
WIRE CONNECTOR/H 3P L=120MM
EX07N48192
J103
WIRE CONNECTOR/H 12P
EX07N48103
J108
WIRE CONNECTOR/H 14P
EX07N48104
J105
WIRE CONNECTOR/H 9P L=140MM
EX07N48190
WIRE CONNECTOR/H 6P-2P L=500/400
EX07N49158
EB-99(J2)(MIO-12)
EX07N48192
VOI-M-VOL-
LEAD WIRE #26 50MM BLACK 5:5
WL0005005Z
MIC GAIN,
WL0005005Z
ECHO (SW)-ECHO(VR)
WL0005005Z
3N-RF SW
LEAD WIRE #26 60MM RED 5:5
WL0206005Z
3N-RF SW
LEAD WIRE #26 60MM YELLOW 5:5
WL0406005Z
3N-ECHO SW
LEAD WIRE #26 90MM BLACK 5:5
WL0009005Z
3N-D113
LEAD WIRE #26 150MM BLUE 5:15
WL0615004Z
ECHO SW-TR30
LEAD WIRE #26 250MM BLUE 5:15
WL0625004Z
CLAMP GT-100M
GZZZ50000Z
FRONT PANEL
PT148N010A
FRONT CHASSIS
MT3600010S
CHANNEL BRACKET
MT3600041S
TOP HOUSING
MT3600061X
BOTTOM HOUSING
MT3600071X
FOAM 15x30x11t
XZZZ90021Z
MASK PLATE(SW)
XZZZ90296A
SOLDER PLATE
XZZZ90098Z
T&B HOUSING(4)
SHIELD CLOTH 10x88x0.3t
LZZZ60001Z
ID PLATE DX-33HML
BT0148011F
Front Panel(4)
SET SCREW M3x0.5Px8
JS033008MN
SWR SW(2)
SET SCREW M2.6x0.45Px5
JS052605MN
CHASSIS(14)
SET SCREW M3x0.5Px6
JS053006MN
Main PCB(7)
SET SCREW T3x6-2mm
JS053006TN
H BKT(2)
SET SCREW T3x8-2 STEEL
JS013008TH
MOUNTING SCREW BLACK
XZZZ90007Z
HANDLER
FIBER WASHER
XZZZ90188Z
DC CORD W/FUSE SOCKET
WA0012185A
MICROPHONE ASSY BLACK DMC507-012 4P
EX04N40002
FUSE 16V 4A
EX02N40008
SET SCREW W5x10-1
JS015010WH
SET SCREW T3.5x8-2
JS013508TH
OUT-TOOTH WASHER 5.5x10x0.3tmm
JW315510CN
IN-TOOTH WASHER 4x8x0.3tmm
JW324008CN
Copyright © 1998,1999,2000, 2001, 2002, 2003 CBTricks.com
