Galaxy
DX Radios DX33HML
Receiver Alignment
See Required
test equipment
See Alignment
Locations
SETTINGS | CONNECTION |
ADJUST
ADJUST FOR |
AM/FM
RF & IF SENSITIVITY: Frequency to 26.965 MHz Mode AM Clarifier controls at center detent. RF GAIN fully clockwise. SQUELCH fully counter clockwise NB/ANL to OFF VOLUME to comfortable level. RF Generator output to 26.965 MHz at 1uV modulated 30% with 1 KHz audio tone. |
Connect
AF VTVM or scope across speaker terminals. RF Generator to ANT Jack |
(in
order)
L6, L7 L8, L10 L11, L12 L3, L4 |
Adjust for max. output reading on AF VTVM or Scope. |
Set mode
to AM. Set frequency to Ch.1 lowest band, then Ch.40 highest band as required. |
Same as above |
L6,
L7
Recheck sensitivity across full radiobandwidth. If necessary, retune L6 & L7 to balance RF sensivity across bandwidth. |
FM
DETECTOR: Mode FM. Set FM RF Generator to 26.965 MHz 0.5uV deviated 3 KHz with 1KHz audio tone. Reduce VOLUME as required. |
Connect
AF VTVM or scope to IC2 Pin 7. RF Generator to ANT Jack |
L5 |
Adjust for maximum audio output. |
AM/FM
S-METER: Set mode to AM. RF Generator output to 100uV unmodulated. Set Squelch fully counterclockwise. |
Same as above |
VR1
Adjust for “S-9” meter reading. |
AM/FM
SQUELCH RANGE: Increase RF Generator output to 10mV. Set Squelch Control fully clockwise. |
Same as above |
VR4
Adjust to the squelch just closes. |
NOISE
BLANKER: Set radio to 26.975MHz Set mode to AM. Set RF generator output to 26.965MHz at 1000uV unmodulated. Set NOISE BLANKER switch to “ON”. |
Connect DC Voltmeter to TP1 (Cathode of D2). |
L1, L2 |
Adjust for maximum DC voltage. |
