Galaxy
DX Radios DX33HP (MOSFET Final)
Main PCB (EPT360014B)
Crystals
Ref#
Description |
MFR.
Part No.
X1 |
CRYSTAL HC-49U 10.240MHZ 20PPM |
EYCAB10240 |
X2 |
CRYSTAL HC-49U 14.010MHZ 20PPM |
EYCAA14010 |
X4 |
CRYSTAL HC-49U 10.6975MHZ 10PPM |
EYBAE10697 |
Filters
Ref#
Description |
MFR.
Part No.
FL1 |
CERAMIC FILTER CFW-455HT |
EFCFW455HT |
FL2 |
CERAMIC FILTER SFE10.7MX RED |
EFCFE107MX |
Inductors
Ref#
Description |
MFR.
Part No.
L1 |
I.F.T. |
ECIFT12000 |
L2 |
I.F.T. |
ECIFT12001 |
L3 |
I.F.T |
ECIFT12002 |
L4 |
I.F.T |
ECIFT12002 |
L5 |
I.F.T. |
ECIFT12003 |
L6 |
I.F.T. |
ECIFT12004 |
L7 |
I.F.T. |
ECIFT12005 |
L8 |
I.F.T. |
ECIFT12022 |
L10 |
I.F.T. |
ECIFT12007 |
L11 |
I.F.T. |
ECIFT12007 |
L12 |
I.F.T. |
ECIFT12008 |
L15 |
BEAD COIL D 3.5X6X1.2 |
ECBAD18504 |
L17 |
I.F.T. |
ECIFT12017 |
L18 |
I.F.T. |
ECIFT12010 |
L20 |
I.F.T. |
ECIFT12012 |
L22 |
I.F.T. |
ECIFT12258 |
L24 |
ECBAD18504 |
L26 |
I.F.T. 113CN-6344Z |
ECIFT12016 |
L31 |
SPRING COIL 0.8x6x8.5t |
ECSPG18075 |
L37 |
SPRING COIL 0.8x3x4t |
ECSPG18090 |
L38 |
BEAD COIL F RH3.5x6.0x0.8 AT |
ECBAD18506 |
L39 |
SPRING COIL 0.8x4.2x6.5t |
ECSPG18000 |
L40 |
I.F.T. |
ECIFT12014 |
L41 |
BEAD COIL WBRH-3.5x6x0.8-U16 |
ECBAD18555 |
L42 |
I.F.T. |
ECIFT12015 |
L43 |
I.F.T. |
ECIFT12010 |
L44 |
I.F.T. |
ECIFT12007 |
L51 |
SPRING COIL 0.8x6x3.5t |
ECSPG18089 |
L52 |
ECSPG18089 |
L53 (L33-L34) |
SPRING COIL 1.0x6.5x7.5tmm |
ECSPG18412 |
L503 |
BEAD COIL RH-7.75x13x4 |
ECBAD18585 |
T1 |
CHOKE COIL 1.1MH (EI-19) |
ECCHK16004 |
