Galaxy
DX Radios DX44V
CHASSIS PARTS
Ref#
Description |
MFR.
Part No.
DC JACK 3P |
EX06T40007 |
DIODE LT6A400 |
EDLT6A400Z |
DC SKT |
C/C 0.01UF 50WV SL Z |
CC0501037L |
DC SKT |
SET SCREW M3x0.5Px8 |
JS053008MN |
DC SOCKET HOLDER |
MT3600050X |
SET CHASSIS |
MT3001024M |
ANT JACK CH-239(A) |
EX06N41019 |
ANT JACK |
JUMPER WIRE 7x50mm x7 |
WX01070750 |
ANT JACK |
SOLDER PLATE |
XZZZ90098Z |
Ref#
Description |
MFR.
Part No.
E-TONE |
V/R 50KA/50KB W/SW |
RV50303433 |
VOI-SO |
V/R 50KB/50KA/SW |
RV50303344 |
MIC GAIN-RF GAIN |
V/R 1KB/1KA |
RV10203345 |
RF POWER |
V/R 1KA |
RV10203404 |
Ref#
Description |
MFR.
Part No.
ROTARY SW 4N |
EWRT32008S |
ROTARY SW 3N BAND (FM/AM/PA) |
EWRT32001S |
SLIDE SW 3N |
EWSL31000S |
SLIDE SW 2N |
EWSL31001S |
Ref#
Description |
MFR.
Part No.
SPEAKER 8 ohm 3W 3.5in |
ES300835SQ |
Speaker |
JS053008MN |
Speaker |
NUT WITH WASHER M3x3.5t |
JN263035ZS |
Ref#
Description |
MFR.
Part No.
SIGNAL METER L=250mm |
EX03N40407 |
METER HOLDER |
PT3600080A |
Ref#
Description |
MFR.
Part No.
J109 |
WIRE CONNECTOR/H 2P L=180MM |
EX07N48041 |
J101,104 |
WIRE CONNECTOR/H 4P 160MM |
EX07N41355 |
ECHO(J2)(MIO-12) |
WIRE CONNECTOR/H 3P L=120MM |
EX07N48192 |
J103 |
WIRE CONNECTOR/H 12P�� PCS |
EX07N48103 |
J108 |
WIRE CONNECTOR/H 14P�� PCS |
EX07N48104 |
ECHO(J2)(MIO-12) |
EX07N48192 |
WIRE CONNECTOR/H 6P-2P L=500/400 |
EX07N49158 |
BAND PCB(J1)-MAIN PCB |
WIRE CONNECTOR/H 12P L=100mm PH=2mm |
EX07N49256 |
BAND PCB(J2)-ROTARY SW P CB(J304) |
WIRE CONNECTOR/H 10P-9P L=150 2.5/2 |
EX07N49273 |
BAND PCB(J3)-4N SW |
WIRE CONNECTOR/H 9P PH=2mm L=210mm |
EX07N49274 |
VOL-M-,VOL-MIC GAIN,H/L-BEEP |
LEAD WIRE #26 50MM BLACK 5:5 |
WL0005005Z |
BAND SW-H/L |
LEAD WIRE #26 50MM RED 5:5 |
WL0205005Z |
H/L-BAND SW |
LEAD WIRE #26 60MM YELLOW 5:5 |
WL0406005Z |
H/L-+10KHZ |
LEAD WIRE #26 60MM VIOLET 5:15 |
WL0706004Z |
LEAD WIRE #26 100MM YELLOW 5:5 |
WL0410005Z |
BEEP-ROTARY SW PCB |
LEAD WIRE #26 120MM RED 5:5 |
WL0212005Z |
D113(MAIN)-3N SW(10) |
LEAD WIRE #26 150MM BLUE 5:15 |
WL0615004Z |
LEAD WIRE #26 180MM ORANGE 5:5 |
WL0318005Z |
Ref#
Description |
MFR.
Part No.
SWx1 |
DIODE 1N4148 |
ED1N04148Z |
Ref# | Description |
MFR.
Part No.
FRONT PANEL |
PT148N010A |
LED DISPLAY HOLDER |
PT3600060A |
LED DISPLAY WINDOW RED |
PT3600070A |
Ref#
Description |
MFR.
Part No.
KNOB WASHER |
PT3600090A |
KNOB C-1 |
PT3600120A |
KNOB (A-1) |
PT3600101A |
KNOB B-1(CHROM) |
PT3600110A |
KNOB D-1(CHROM |
PT3600130A |
Ref#
Description |
MFR.
Part No.
FRONT CHASSIS |
MT3600010S |
CHANNEL BRACKET |
MT3600041S |
TOP HOUSING |
MT3600061X |
BOTTOM HOUSING |
MT3600071X |
D SPRING A #6600 |
MT3600080T |
D SPRING B #7800 |
MT3600090T |
D SPRING D #8500 |
MT3600100T |
FOAM 15x30x11t |
XZZZ90021Z |
SOLDER PLATE |
XZZZ90098Z |
MASK PLATE(SW) |
XZZZ90296A |
SHIELD CLOTH 10x88x0.3t |
LZZZ60001Z |
CLAMP GT-100M |
GZZZ50000Z |
Front Panel(4) |
JS033008MN |
Tone(2) |
SET SCREW M2x0.4Px4 |
JS052004MN |
CH9(2) |
JS052004MN |
WB/Anl SW(2) |
JS052004MN |
SWR SW(2) |
SET SCREW M2.6x0.45Px5 |
JS052605MN |
CHASSIS(12) |
SET SCREW M3x0.5Px6 |
JS053006MN |
Main PCB(5) |
SET SCREW T3x6-2mm |
JS053006TN |
SET SCREW T3x8-2 STEEL |
JS013008TH |
MIC STOPPER |
XZZZ90008Z |
MOUNTING SCREW BLACK |
XZZZ90007Z |
FIBER WASHER |
XZZZ90188Z |
DC CORD W/FUSE SOCKET |
WA0012185A |
MICROPHONE ASSY,4P BLACK DMC507-012 |
EX04N40002 |
FUSE 16V 4A |
EX02N40008 |
SET SCREW W5x10-1 |
JS015010WH |
SET SCREW T3.5x8-2 |
JS013508TH |
OUT-TOOTH WASHER 5.5x10x0.3tmm |
JW315510CN |
IN-TOOTH WASHER 4x8x0.3tmm |
JW324008CN |
