Galaxy DX Radios DX44V
Main PCB (EPT360014B) (EPT360014C)
Connectors
Ref#
Bd Loc
Description
MFR. Part No.
J101
F6
PCB CONNECTOR/S 4P T PH=2.5(WHITE)
EX07N41343
J103
E4
PCB CONNECTOR/S 12P T PH=2.5 WHITE
EX07N41309
J104
E3
EX07N41343
J107
E2
PCB CONNECTOR/S 2P PH=2.5
EX07N41226
J108
F4
PCB CONNECTOR/S 14P TPH=2.5 WHITE
EX07N41369
J109
A6
PCB CONNECTOR/S 2P T PH=2.5(WHITE)
EX07N41330
MIC
F6
PCB CONNECTOR/S 3P T PH=2.5(WHITE)
EX07N41227
J501
A5
EAR JACK 3.5mm
EX06N41045
J502
A6
EAR JACK 3.5mm
EX06N41045
Wire
Ref#
Description
MFR. Part No.
J211-210
LEAD WIRE #26 150MM YELLOW 15:3
WL0415003Z
J62-TR39
LEAD WIRE #26 150MM RED 15:15
WL0215009Z
J10-J104
LEAD WIRE #26 170MM WHITE 15:15
WL0917009Z
J15-J104
LEAD WIRE #26 170MM GREEN 15:15
WL0517009Z
AMP-J104
LEAD WIRE #26 200MM RED 15:15
WL0220009Z
R275-G
LEAD WIRE #26 200MM VIOLET 15:15
WL0720009Z
L30-PA
LEAD WIRE #26 250MM WHITE 15:15
WL0925009Z
L29-SPK
LEAD WIRE #26 250MM VIOLET 15:15
WL0725009Z
Jumpers
Ref#
Bd Loc
Description
MFR. Part No.
J3
B6
JUMPER WIRE 7x15x7mm
WX01070715
TUBE 1.2x13mm
WX0012013A
J4
B6
JUMPER WIRE 7x30x7mm
WX01070730
J5
D6
WX01070715
TUBE 1.2x13mm
WX0012013A
J6
D6
JUMPER WIRE 7x6x7mm
WX01070706
J7
D6
WX01070715
J8
D6
JUMPER WIRE 7x5x7mm
WX01070705
J9
F5
JUMPER WIRE 7X9x7mm
WX01070709
J12
B5
JUMPER WIRE 7x20x7mm
WX01070720
J13
C4
JUMPER WIRE 7x8x7mm
WX01070708
J14
C4
JUMPER WIRE 7x12x7mm
WX01070712
J18
C4
JUMPER WIRE 7x8x7mm
WX01070708
J19
C5
JUMPER WIRE 7x25x7mm
WX01070725
J20
D5
WX01070715
J21
D5
JUMPER WIRE 7x35x7mm
WX01070735
J22
D5
JUMPER WIRE 7x8x7mm
WX01070708
J23
E5
WX01070725
J25
E6
JUMPER WIRE 7X9x7mm
WX01070709
J26
F5
WX01070715
J27
F5
WX01070715
J28
C4
JUMPER WIRE 7x14x7mm
WX01070714
J29
A3
WX01070720
J30
B3
JUMPER WIRE 7x6x7mm
WX01070706
J31
B3
JUMPER WIRE 7x7x7mm
WX01070707
J32
B3
WX01070715
J33
B3
JUMPER WIRE 7x7x7mm
WX01070707
J35
D3
JUMPER WIRE 7x6x7mm
WX01070706
J37
F5
JUMPER WIRE 7x22x7mm
WX01070722
J38
F5
WX01070714
J39
F5
WX01070712
J40
B3
JUMPER WIRE 7x8x7mm
WX01070708
J41
A2
WX01070714
J42
B2
JUMPER WIRE 7x8x7mm
WX01070708
J43
C2
JUMPER WIRE 7x8x7mm
WX01070708
J44
D2
JUMPER WIRE 7x6x7mm
WX01070706
J45
C3
JUMPER WIRE 7x8x7mm
WX01070708
J46
D3
WX01070712
J49
JUMPER WIRE 7x5x7mm
WX01070705
J50
F4
JUMPER WIRE 7x6x7mm
WX01070706
J51
F4
JUMPER WIRE 7X9x7mm
WX01070709
J52
F4
JUMPER WIRE 7x6x7mm
WX01070706
J53
F4
JUMPER WIRE 7x10x7mm
WX01070710
J54
E2
JUMPER WIRE 7x5x7mm
WX01070705
J57
C2
JUMPER WIRE 7x8x7mm
WX01070708
J58
C1
WX01070710
J57
C1
JUMPER WIRE 7x8x7mm
WX01070708
J59
B5
JUMPER WIRE 7x18x7mm
WX01070718
J60
E4
JUMPER WIRE 7x8x7mm
WX01070708
J61
E4
JUMPER WIRE 7x8x7mm
WX01070708
J63
JUMPER WIRE 7x8x7mm
WX01070708
J65
E1
WX01070710
J66
E1
JUMPER WIRE 7x5x7mm
WX01070705
J67
E2
JUMPER WIRE 7x8x7mm
WX01070708
J68
E1
JUMPER WIRE 7X9x7mm
WX01070709
J76
B2
WX01070712
J78
A2
JUMPER WIRE 7x13x7mm
WX01070713
J84
F3
WX01070710
J85
F3
WX01070710
J86
E3
JUMPER WIRE 7x7x7mm
WX01070707
J87
E3
JUMPER WIRE 7x8x7mm
WX01070708
J88
E3
JUMPER WIRE 7x6x7mm
WX01070706
J89
E3
JUMPER WIRE 7x5x7mm
WX01070705
J91
E2
JUMPER WIRE 7x5x7mm
WX01070705
J92
E2
JUMPER WIRE 7x6x7mm
WX01070706
J94
C3
WX01070712
J95
C2
JUMPER WIRE 7x8x7mm
WX01070708
J99
A6
JUMPER WIRE 7x5x7mm
WX01070705
J100
A6
JUMPER WIRE 7x5x7mm
WX01070705
J102A
D2
WX01070710
J110
C1
JUMPER WIRE 7x8x7mm
WX01070708
J111
E1
JUMPER WIRE 7x8x7mm
WX01070708
J111A
C1
JUMPER WIRE 7x8x7mm
(EPT3600-14C ONLY)
WX01070708
J119
WX01070714
R80
D3
WX01070712
R233
E4
WX01070710
R275
F2
JUMPER WIRE 7x4x7mm
WX01070704
C93
D1
JUMPER WIRE 7x4x7mm
WX01070704
C96
D1
JUMPER WIRE 7x4x7mm
WX01070704
C111
E3
JUMPER WIRE 7x4x7mm
WX01070704
C228
E3
JUMPER WIRE 7x3x7mm
WX01070703
C230
E2
JUMPER WIRE 7x3x7mm
WX01070703
C330
F2
JUMPER WIRE 7x3x7mm
WX01070703
FL3
D2
WX01070715
D19
WX01070715
D18
D2
WX01070715
D35
E2
JUMPER WIRE 7x3x7mm
WX01070703
D57
E3
JUMPER WIRE 7x4x7mm
WX01070704
D59
E3
JUMPER WIRE 7x4x7mm
WX01070704
D74
JUMPER WIRE 7x6x7mm
WX01070706
IC3-C19
E3
WX01070715
TP7-TP9
A3
WX01070713
TP8-TP7
A2
WX01070725
TR13
B4
JUMPER WIRE 7x3x7mm
WX01070703
B+
JUMPER WIRE 7x7x7mm
WX01070707
Copyright © 2003, 2004 CBTricks.com
